250watt photoflood in a walmart fixture??
Discussion in 'Photography Beginners' Forum' started by AdamZx3, Apr 25, 2007.
  1. AdamZx3
    AdamZx3 TPF Noob!
    Apr 13, 2007
    205
    NE Ohio
    I bought some cheaper clamp on floodlights that have a max of 150 watts...is it safe to run the 250watt photofloods in these? I ran a 200watt regular bulb for 30+min in a softbox umbrella and its was fine, a bit warm but not hot,as well as the cord.
    Also I have these that I bought on ebay 2 for 20 shipped
    [​IMG]
    no clue on the wattage limit?
    is there a way to test it out and see if its safe?? I have an extinguisher on the desk and never leave them on and unattended.
    P.S. incase anyone wants to know...those AC lamp brackets above from ebay are junky, certain bulbs screw in real hard (making one of them flex and crack slightly) I bought them thinking I would save on spending 15 bucks on an umbrella adapter for the lightstand...:x
    I'm using the silver lined umbrella softboxes if that makes a differance for my question.
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Theres only really 2 possible reasons for a wattage rating. Heat problems and electrical conductor size. If heat isn't an issue then that's one solved. Just be careful as there's a chance you could start an electrical fire inside the unit if the power rating is beyond the rating of the cables.
    Without assuming any responsibility it is normally managable to run at higher wattage when considering conductor size, but do so AT YOUR OWN RISK.
  3. JDP
    JDP TPF Noob!
    Aug 16, 2006
    285
    Minneapolis, MN
    Indeed, what Garbz said. Also, to get UL listed, lights have a certain wattage limit that the UL says is safe to run 24/7. Typically, a larger bulb will be fine for short periods of time - the greatest harm is to the filament itself, the extra heat will burn them out quicker - just be safe!
  4. cosmonaut
    cosmonaut No longer a newbie, moving up!
    Oct 12, 2006
    1,122
    98
    North Georgia
    It's not the wire size that is the issue it's the heat in the socket. It will more than likely burn your fixture up over time but not in an hour or two.
    Cosmo
    I am an electrician.....
  5. AdamZx3
    AdamZx3 TPF Noob!
    Apr 13, 2007
    205
    NE Ohio
    oooh cool :)
    so would I be pushing it with 300 ? or cough....500...cough ?
    I'm not to worried about life span, hopefully I will be graduated and working again in 4 months.....then some AlienBee 800's!
  6. reshp1
    reshp1 TPF Noob!
    Mar 26, 2007
    58
    If you can get a fan and blow some air on the thing it will really help keep it cool. Things heat up much faster and to a much higher temp in still air.
  7. Mike_E
    Jan 26, 2007
    5,327
    266
    Get a couple of pieces of stove pipe (8" triple wall) and screw them to your fixtures to make a spot light. With a short barrel you will get the diffraction you need and won't have to bake your subjects.
    mike
