28mm - 135mm IS lens
Discussion in 'Photography Beginners' Forum' started by Byrdman, Mar 18, 2007.
  1. Byrdman
    Byrdman TPF Noob!
    Jan 29, 2006
    26
    Can I use this len for macro or is it not suggested.
  2. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    Minimum focus distance is .5 meters. If thats close enough for you then go ahead and give it a shot... but it is not a true macro lens.
  3. Byrdman
    Byrdman TPF Noob!
    Jan 29, 2006
    26
    Thanks. Do you think a lens like the sigma 105mm would be better?
  4. xfloggingkylex
    xfloggingkylex TPF Noob!
    May 5, 2006
    1,292
    Frederick, MD
    if you like the 28-135, get it, and pick up some macro extension tubes as well. These glassless extenders push the lens further away from the sensor, allowing you to focus much closer with the sacrafice of no focus to infinity. The more space you add the closer you can get to your subject. I should add that manual focus may be required, but you'll be so close you'll be able to see what you are doing.
    Of course if you are buying a lens to fill the macro gap in your kit, you'd may be better off buying a macro dedicated lens. If however you just like the 23-135 (and who doesn't), macro extension tubes will put it in the macro catagory no problem.
  5. Byrdman
    Byrdman TPF Noob!
    Jan 29, 2006
    26
    Thanks a million Think thats what im going to do
  6. Groupcaptainbonzo
    Groupcaptainbonzo TPF Noob!
    Nov 9, 2006
    463
    Turners Hill, West Sussex, UK.
    [​IMG][​IMG]A true macro lens will give a reproduction of 1 : 1 (Image same size on sensor as in real life. and because of the very close focus distance has a very flat plane which reduces distortion.
    Non Macro lenses will not have this facility. The amount of distortion varies with differing lenses and only YOU can say if it is acceptable or not.
    I use the Sigma 105mm and find it phenominal...
  7. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    The Sigma is a true 1:1 lifesize Macro and way better than the 28-135. Sharp sharp sharp.
    But if you are looking for a 1 lens to do everything, I'd search more.
28mm-135mm macro add ons
28mm135mm
rokinon 135mm macro lense no 711562
