2nd Day with kenko extension tubes C&C
Discussion in 'Photography Beginners' Forum' started by Rockern1, Mar 20, 2010.
  1. Rockern1
    Rockern1 TPF Noob!
    Feb 20, 2010
    35
    Hello
    Well these are some pics i took about an hour ago i hope this time a did a better job focusing.
    these were shot with Canon Rebel xsi 18-55mm lens and kenko extension tubes. Im not sure how many tubes i used for each shot cause i was switching around but i mostly shot with 3 tubes. All pics were shot hand held, dont have a tripod:( and it was king windy so the flowers were rocking back and forth.:confused:
    1. f/22 1/60 ISO100 Flash:fired
    [​IMG]
    2. f/22 1/40 ISO100 Flash: not fired
    [​IMG]
    3. f/36 1/30 ISO200 Flash: not fired
    [​IMG]
    4. f/36 1/20 ISO200 Flash: not fired
    [​IMG]
    5. f/11 1/60 ISO100 Flash: not fired
    [​IMG]
    6. f/11 1/60 ISO100 Flash: not fired
    [​IMG]
    7. f?22 1/50 ISO400 Flash: not fired
    [​IMG]
  2. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    A couple of these are pretty sharp, but... one thing I would do is to make sure you have a higher shutter speed. With the magnification you're getting, and the three tubes it is costing you a lot of light (and of course the fact that you're using f/22).
  3. Rockern1
    Rockern1 TPF Noob!
    Feb 20, 2010
    35
    thanks Nate ill try to switch thing around to get more shutter speed
  4. JeffieLove
    JeffieLove TPF Noob!
    Feb 8, 2010
    1,600
    14
    Elkton, MD
    You woul probably be safe using f/14 or so with these which shoul allow you to mor than double the shutter speed.
    Do you have an external flash as well? Or just the pop up flash?
    Also with the extension tubes, from what I was told, you should put the amount of tubes on that = the focal length you are shooting at.
    If you are shooting at full zoom with that lens at 55mm then you should try to have 55mm (or close to it) in tubes attached. That will give you 1:1 macro.
  5. Rockern1
    Rockern1 TPF Noob!
    Feb 20, 2010
    35
    thanks Jeffie ill look into how to properly use the tubes with my lens, and i only have the pop up flash.
  6. Ron Evers
    Ron Evers Been spending a lot of time on here!
    Jun 28, 2008
    6,114
    1,976
    In the country just north of Toronto, Canada
    I do not understand the obsession with getting a 1:1 macro. I use the magnification I want for an image, be it more or less than 1:1. I see no magic in 1:1.
    Peppercorn on the end of a pin
    [​IMG]
    [​IMG]
    Edit to say you are doing very well for your second day. Way to go! Macro can be a lot of fun.
  7. Rockern1
    Rockern1 TPF Noob!
    Feb 20, 2010
    35
    Im still kinda new to macro photography and not really sure what these number stand for 1:1:confused:???
  8. chammer
    chammer TPF Noob!
    Jul 30, 2009
    642
    5
    Virginia Beach, VA
    1:1 simply means actual (or life) size.
  9. Rockern1
    Rockern1 TPF Noob!
    Feb 20, 2010
    35
    oh alright thanks chammer
kenko
kenko extension tube and teleconverter for gf1
kenko extension tubes gf1
kenko extensions tube gf1
kenko tubes 40-150
