2x lens converter
Discussion in 'Photography Equipment & Products' started by mike11165, Aug 10, 2008.
  1. mike11165
    mike11165 TPF Noob!
    Aug 3, 2008
    26
    dallas
    Do lens converters sacrifice the quality of the lens/shots? seems like a cheap way to enhance your lens, but is it effective or just beginner trash equipment?
  2. gryphonslair99
    gryphonslair99 Been spending a lot of time on here!
    Sep 9, 2006
    13,588
    2,566
    Wichita, Kansas, USA
    Yes, they will always affect the quality of your shots.
    Depending on the converter and the lens that you use it on it can either be trash or very effective. A $50.00 converter is not going to be well engineered or made of high quality materials. If however you are willing to spend some serious money for a top line Canon, Nikon, Sigma, Kenko or other lens makers for a converter that is suitable for your equipment you can get some pleasing results. If you use it on the type of lenses that converters are designed for and If you are using it on good (write in expensive most of the times) glass you can get very acceptable results.
    Converters are a compromise. With a 1.4X converter you loose one f-stop. With a 2X converter you loose 2 f-stops. Converters are really not designed to work on short focal length lenses. The basic minimum is a lens that is no shorter than 100mm. They tend to work better on primes than zooms. Zooms in general are softer than primes; be it a tad in a high quality zoom or quite a bit in your general consumer grade zoom.
    A converter is going to magnify any flaws from that lens. If the lens is already soft the shots will be softer with a converter. I have Canons 1.4 converter and do use it on occasion when I need the reach. On my 70-200 f2.8 I can get acceptable shots (by my standards) at the 200 end. On my 400 f2.8 however I love it. The 400 f2.8 is an incredibly sharp lens and the IQ degradation is very acceptable with the 1.4 on it.
    Personally I prefer the 1.4X to the 2X converter. The extra reach of the 2X also means an increase in IQ degradation.
  3. Overread
    May 1, 2008
    23,492
    3,971
    UK - England
    Firstly check the manufacturers website to make sure your lenses can take the teleconverter - the canon line only work for selected (most) L lenses in the range - sigma and tamron lines do work well though with many lenses.
    But yes you are right - they are adding glass to a lens setup and so do lower the overall quality of shot and also increase the amount of light you need to get a good shot (and also lower your maximum aperture - 1.4 times is by one stop and 2 times is by two stops).
    However you are right that they are a good and cheap way to add focal length to a lens - however unless you are using top range lenses you won't gain enough range to counter the loss in quality. Most 1.4 times on a top range lens add focal length with minimal losses of light and quality - its a very worth while and popular teleconverter to use - the 2 times is more of a gamble - more range, but more restructions and limitations.
    Further primes are far better at this than zooms (especially with the 2 times teleconverter
  4. mike11165
    mike11165 TPF Noob!
    Aug 3, 2008
    26
    dallas
    i consider myself enlighted by you two, thanks for taking the time to teach a noob.
  5. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    Look in just for fun, Overread posted a topic about exparimenting with two teleconverters on a mid range zoom to extend it to 800mm.
    If I had a good 200mm tele I would offer up a 200/2xconvert vs 400mm tele, but sadly I do not have the 200mm at this time.
    *EDIT*
    http://thephotoforum.com/forum/showthread.php?t=131121
  6. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    As said you lose quality but I generally find it to not be as bad as actually upsampling the image. (and before someone shouts genuine fractals, note that my teleconverter cost as much as that piece of software)
    2x teleconverters are generally pushing it for any lens you mount it on but certainly 1.4x (I use) and 1.7x are widely used for giving a bit of extra reach to existing good lenses.
    Also note that this is not one of the times to be brand proud. A quick google search will show that Kenko regardless of their poor other products make a fantastic teleconverter, and definitely a much higher bang for buck and far better supported product (Doesn't lose AF on any lens) then even Nikon's own. (no comment on Canon)
    I suggest take the camera into a shop which sells them and have a play at the counter, let me know if you want example shots for a 1.4x and I'll go take some tomorrow.
  7. Bifurcator
    Bifurcator TPF Noob!
    Jun 1, 2008
    3,312
    Japan
    Hehehe was that to me? :D But no need for the prevention I totally agree. Genuine Fractal is nice but I would MUCH rather work with a TC given the option of the two!
  8. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    345
    North New Jersey, United States of America
    Yes... Image quality is compromised but I wouldn't consider them "trash".
    cropping versus 2x converter? I'd take the 2x converter.
    not getting the shot versus 2x converter? I'd take the 2x converter and enjoy shooting
    300mm AND 600mm versus 2x converter AND 300mm on a long long hike? I'd take a 2x converter (unless you have a human mule to carry the 600mm it for you).
  9. gryphonslair99
    Sep 9, 2006
    13,588
    2,566
    Trust me, I have seen this lens:
    Phoenix Zoom Telephoto 100-300mm f/5.6-6.7 Autofocus Lens for Canon EOS $109.99
    With this TC:
    PHOENIX 2X TELE CONVERTER AF CANON EOS $69.00
    The shots are not worth taking. :)
    It isn't that way with every TC or lens, but it important for the OP to understand that the TC will magnify the faults of the lens as well as the faults of the TC.
  10. gryphonslair99
    Sep 9, 2006
    13,588
    2,566
    :thumbup: Got to agree with Garbz. I had the Kenko DG 300 1.4X converter. I thought it was as good as the Canon at half the price.
  11. icassell
    icassell TPF Noob!
    Jun 7, 2008
    9,893
    10
    Arizona
    I have the Sigma 1.4X and the Sigma 2X to use with my SIgma EX glass. They degrade IQ somewhat and the 2X more than the 1.4X, but both often give very good results. I've stacked them on my Sigma EX 100-300 f4 zoom -- not great, but don't know how else I could ever afford an 820mm lens! I bought my TC's on ebay at very good low prices.
  12. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    I used to use them in the film days but, only if absolutely needed. I think I will look at that Kenko though. I dont mid a 1.4/1.7 but, never really liked the 2x. Id rather have glass that reaches out than use a converter. I know my next long range is going to be the Sigma 300-800. And I wont mind carrying it in my pack either. :)
2x lens converter cheep v expensive
2x lens converter
2x converter lens
2x lense converter
apo tele converter 2x dg
lens 2x converter
poenix dg 2 x
sigma 150-500 with teleconverter 2.0x 1000mm
two times converter lense
x2 lens converter
