3 Year plan
Discussion in 'Photography Beginners' Forum' started by asfixiate, Apr 9, 2008.
  1. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    Between now and 3 years from now I hope to have a very good arsenal of equipment to cover any type of event. I'm learning more and more every day so the below might sound beginner but I am avid photographer always reading and researching.
    Canon EOS 5d(primary) with my Rebel XT as backup. Once I am successful I would like to have my primary and backup bodies the same cameras though.
    What I would like to have is me and a colleague/partner basically go to each event so that instead of switching lenses back n fourth one goes in close and one is around the perimeter as well as always covering more than one angle.
    I'm thinking for perimiter shots I go with 70-200 f/2.8(Leaning towards L series.) I use a 75-300 Kit lense now for a lot of action shots(dog park) and feel if I can cover the random shots of dogs running around I could easily cover a lot of distances at a wedding with 70-200. Plus producing a sharp image even better. What you think about this analogy?
    I'm thinking for portraits and headshots I got with either 50mm f/1.4 or an 85mm f/1.4. I am currently using a 50mm f/1.8 for a lot of shots but would like to be a decent distance (within 20 feet) so I'm not breathing down anyone's necks. At a decent distance I feel I could fill the frame a bit better as well.(How far away do you normally stand from portraits.) This might be my OCD but I am extremely anal retentive when I do portait like shots and don't like a lot of permiter in my shots.
    My walk around lense is leaning towards the Canon EF 24-70mm f/2.8 L. I'm reading a lot of possitive reviews about this and think its probably a must have. I could also use this as portrait lense could I not?
    Obviously 3 years from now I'm going to be far more versed in photography and won't really have a lot of these questions but as of now I don't really have ways of testing all this equipment since I'm currently putting away roughtly 1,000 per month for my wedding in October.
    What are your thoughts on my equipment setup above?
    The only lense coverage I feel I'm lacking is before the 24-70mm. I've seen several articles as well as a few threads recommending the 10-20mm but couldn't I just stand further back with the 24-70mm?
  2. Village Idiot
    Mar 20, 2008
    7,274
    406
    Several articles that are most likely talking about the 24-70 on a 1.6x crop camera.
    A wide angle lens on the 5D is the Canon 17-40L.
    Plus keep in mind, the 5D will not use EF-S mount lenses.
  3. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    The lenses are more goals than the camera at this point. I'm not set in stone on what camera to upgrade to yet. Mainly because I don't know if a 40d is enough horsepower and if a MarkIII is overkill. 5d was in between and its acting as a filler in my budget/business plan.
  4. Village Idiot
    Mar 20, 2008
    7,274
    406
    Well Canon may upgrade the 5D. You'll probably be paying $2500-$3500 for one.
    The downside of the 5D is some of the features aren't up there with the newer cameras, but the IQ is. A lot of wedding photogs and model photogs use it.
    But keep in mind, the 5D is FF and will completely change the way your lens lineup acts. A 50mm on a APS-C sensor Canon has the field of view of an 80mm lens, so a 50mm lens on a 40D will give you approximately the same field of view as an 85mm lens on the 5D.
    The Sigma 10-20 won't work below 17mm on a FF sensor iirc and the Canon 10-22 is an EF-S mount. Some more info below.
    FL FOV FF-----FL FOV APS-C
    10mm-20mm = 16mm-32mm
    17mm-40mm = 27.2-64
    24mm-70mm = 38.4mm-112mm
    70mm-200mm = 112mm-320mm
  5. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
  6. TheOtherBob
    TheOtherBob TPF Noob!
    Mar 27, 2007
    289
    UWS, NY, NY
  7. McQueen278
    McQueen278 TPF Noob!
    Mar 24, 2008
    388
    Ann Arbor, MI.
    Trust me, the 40D lacks no horsepower. In some ways it is more useful than the 5D. It will shoot at 6.5fps as apposed to the 5D's 3fps. The 40D utilizes EF-S lenses. I personally love the 10-22mm. The 5D is full frame, whereas the 40D has the 1.6x crop factor. For doing weddings I would say you don't need more than the 40D, but if you start shooting for a magazine ad want gigantic prints then go with the 5D, but then again if you are doing that sort of work why would you not use the latest 1D? Find someone with a 40D and play with it, you'll probably like it and when you start to play with the lenses like the 10-22mm you'll love it.
  8. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    Agreed. Thanks.
  9. Mystwalker
    Mystwalker TPF Noob!
    Jan 25, 2008
    544
    In three years (less, I hope) there will be a 5D mkII or 6D or 7D ... whatever they call it, it will be an improvement over 5D and 40D.
    Hope they have a 17-55 f/2.8L IS by that time - probably be in the $1500 range. That plus 70-200 f/2.8L IS should cover most normal ranges.
  10. KOrmechea
    KOrmechea TPF Noob!
    Jan 26, 2008
    212
    Flint, MI
    The 70-200 should be enough for portraits. I wouldn't get the 85 if you've already got that focal length covered with a great zoom lens.
  11. KhronoS
    KhronoS TPF Noob!
    Oct 8, 2007
    345
    Romania, Galati
    These prices are not possible at all... so definitely are a scam.
    For example, on B&H, a 5D costs 2200$ a 70-200mm f/2.8L IS USM costs 1700$ and the 24-70mm f/2.8L costs 1200$ all these are around 5100$ a lot more then their price of 3300$... not mentioning that they are giving a 580EX (around 500-700$), a card ca card reader tripod etc....
    P.S. About the equipment, for start if you don`t have the money to buy lets say a 5D or 40D.. but a XT or XTI, but buy a very good lens a 70-200mm...
    Don't mess with this kind of deals... better go for either ADORAMA or B&H.. they have the best prices and are serious shops. Or even a better advice go to your local store, even is it`s a little more expensive, you'll be able to see the equipment straight in your hands. :)
  12. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    Money is not going to be a problem. The soniccamera post was just more or less me being curious.
    Between now and 3 years from now I'm looking to invest around 10k in equipment. If I can limit the amount of lenses I need to lug around than I feel not only it will be more cost effective as well as less of a pain in the butt. The 3 year plan is really so I feel comfortable charging people as well. I took a 4 year hiatis from my goals due to my current career so I'm just recenlty getting back into photography again. I'm confident the customers will be happy with what I would give them now but want to get solid so I don't make any bad reputation causing mistakes.
    Have
    Canon Rebel XT
    Canon 75-300 mm f/4 - 5.6 III
    Canon EF-S 18-55mm f/3.5-5.6 IS
    Canon EF 50mm f/1.8
    8 GB Ultra II CompactFlash Card
    Will Have(Still working on researching the perfect equipment list)
    Canon EOS 40D(x2)
    Canon EF 70-200mm f/2.8 L IS
    Canon EF 24-70mm f/2.8L
    Canon EF 50mm f/1.4 USM(Not sure about this one yet.)
    580EX II Speedlite
    Quantaray QSX 7001TM Tripod with Built-in Removable Monopod
    If I can get away with taking one of the high costing L lenses from the equation I'd be good. I'm researching Tamron and Sigma as well. If the image quality is the same and the only difference is speed I would go with either. Build quality has to be equal too for them to trump Canon.
