300mm limitations.....
Discussion in 'Photography Equipment & Products' started by puyjapin, Mar 20, 2009.
  1. puyjapin
    puyjapin TPF Noob!
    Nov 5, 2008
    759
    Warwickshire UK
    Ive just got the 70-300vr, which i am very pleased with. Its a nice lens. Im quite new to all this and I was hoping 300mm would give me some reasonable wildlife shots but even at 300mm I cant get close enough really. Only by zooming after thus losing sharpness. Whats the minimum realistically for wildlife/birds??
    Also if i used a teleconverter would the VR still function ok?
  2. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    Birds are usually supposed to be taken with 500mm, and I don't know. I would check by googling it.
  3. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    Most people agree that 500mm is pretty much a minimum for birds and wildlife.
    Take a look Photo.net's Bird Photography FAQs.
    As for teleconverters, you can't use them with slow zooms like the 70-300 VR. For example, the 2x converter costs you two stops of light. This would make the lens an effective 140-600mm f/8 - 11, which is pretty useless, plus you'd have a lack of sharpness from using the teleconverter and using it wide open.
  4. AlexColeman
    Dec 13, 2008
    1,732
    You need a Fixed 2.8 for TC use.
  5. epp_b
    Aug 22, 2008
    2,135
    12
    ^ Fixed f/4 also works with a 1.4x TC.
  6. puyjapin
    puyjapin TPF Noob!
    Nov 5, 2008
    759
    Warwickshire UK
    so fixed means the aperture is not adjustable at all? nut the focal length is adjustable?
  7. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    No, what Alex is talking about...is a lens with a constant maximum aperture.
    For example, your lens has a maximum aperture of what; 4.5 to 5.6? The maximum aperture changes as you zoom the lens.
    A fixed/constant max. aperture lens would be something like the 70-200mm F2.8. It's maximum aperture is F2.8 all the way through the zoom range.
    With either lens, you can still adjust the aperture smaller...but the maximum is the important part to take note of.
  8. puyjapin
    puyjapin TPF Noob!
    Nov 5, 2008
    759
    Warwickshire UK
    well u have enlightened me, sounds ideal, if i had the money!
  9. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    I shoot with a 400mm prime on a film body (full frame), I generally try for roughly 30 to 70 feet from the subject with the occational 30 feet and under.
    lol had a sparrow push me back about ten feet the other day, he was inside minimum focusing range :lol:
  10. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    While you technically don't need a fixed aperture the 70-300 would not work well with a teleconverter. The 1 stop drop in light would cause autofocus to give up completely, and on top of that at 300mm this lens is far from what I would consider sharp enough to bolt on a teleconverter.
  11. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    IMO, a TC on that lens is not a smart purchase. Even with a 1.4TC, the degradation is likely to only piss you off with regard to IQ and then add on to that the drop in aperture.
    I do have a 300mm f/4 prime and a 1.7TC and the results are not that bad. But this is an apples and oranges comparison though.
  12. Montana
    Montana TPF Noob!
    May 27, 2008
    1,533
    Eastern Montana
    If you do not have the funds to get a prime lens longer than 300mm or a 300mm prime and a teleconverter, then I would suggest practicing patience. Seriously! Try sneaking slowly and patiently or hiding and letting the birds and animals come closer to you.
    I am a very impatient man, so I bought the 600mm f/4 IS and just in case I drank too much coffee that morning and am really on edge, I can slap my 1.4 teleconverter on. LOL
