300mm moon
Discussion in 'General Gallery' started by MikeBcos, Dec 17, 2008.
  1. MikeBcos
    MikeBcos TPF Noob!
    Nov 1, 2008
    548
    7
    St. Louis, Missouri
    Taken with my D40 and Quantaray 70-300 lens. 1/640, f8, ISO 200, hand-held.
    [​IMG]
  2. pugnacious33
    pugnacious33 TPF Noob!
    Aug 26, 2008
    757
    21
    MS Gulf Coast
    I think it is slightly underexposed and a little less than sharp, probably due to the handholding. Still a good shot though. It takes alot of tries to get a really good moon. Did you try sharpening it?
  3. MikeBcos
    MikeBcos TPF Noob!
    Nov 1, 2008
    548
    7
    St. Louis, Missouri
    It has had a hint of sharpening, more just made it look unnatural.
    The exposure is subjective, I like it as is, the detail is in the dark areas and none of the highlights are blown.
    This is my first attempt at a moon shot, I did take some on a tripod but the focus was slightly out on them, that was where I learned that the infinity mark on my lens isn't in quite the right place!
  4. astrostu
    astrostu I shoot for the stars
    Aug 1, 2006
    676
    17
    Boulder, CO, USA
    Is there a reason you used f/8? As opposed to something more open?
  5. MikeBcos
    MikeBcos TPF Noob!
    Nov 1, 2008
    548
    7
    St. Louis, Missouri
    It's two stops down from the lens' maximum, that is usually where a lens will give its best quality.
  6. astrostu
    Aug 1, 2006
    676
    17
    Boulder, CO, USA
    Alrighty. I didn't realize that the lens was an f/6.3 - I figured it was like mine, f/5.6 at that focal length (1 stop = f/6.3, 2 = f/7.1, 3 = f/8.0).
  7. MikeBcos
    MikeBcos TPF Noob!
    Nov 1, 2008
    548
    7
    St. Louis, Missouri
    Ummm, OK, you're right :mrgreen: However, I will use the excuse that I am just switching from 35mm and none of the lenses I am used to have 6.3 or 7.1 marked on them!
  8. MikeBcos
    MikeBcos TPF Noob!
    Nov 1, 2008
    548
    7
    St. Louis, Missouri
    OK, I just did some reading, my 35mm days aren't too inaccurate, f6.3 and 7.1 are 1/3 stops, not full stops. The maximum aperture of my lens is f4.5, the closest full aperture to that is f4, two full stops down from that is f8.
  9. astrostu
    Aug 1, 2006
    676
    17
    Boulder, CO, USA
    Okay, I didn't mean a full stop, I meant, effectively, "one change." My understanding in general was that the sharpest point of the lens was around 1-3 "changes" smaller than maximum, so 1/3 to 1 stop smaller. This is also generally what I've seen in reviews of lenses (like my f/1.4 is sharpest at 1.8 or 2.0 in most reviews).
  10. MikeBcos
    MikeBcos TPF Noob!
    Nov 1, 2008
    548
    7
    St. Louis, Missouri
    I guess that varies by lens, my understanding was always two full stops down from maximum. Either way, I'm happy with what I got, I'll try and improve on it but if I never get a better one this one looks great on screen.
  11. Parkerman
    Parkerman TPF Noob!
    Jan 10, 2008
    982
    North Alabama
    Your thing says it is ok to edit.. so.. I introduced the picture to lightroom.
    I adjusted the highlights, lights, darks, and shadows... aswell as the clarity.
    I removed some of the yellow that appeared around the edges and did a little bit of noise reduction.
    [​IMG]
  12. MikeBcos
    MikeBcos TPF Noob!
    Nov 1, 2008
    548
    7
    St. Louis, Missouri
    Thanks Parkerman, I'm on a laptop with a crappy screen right now so I won't comment yet, I'll look again when I get home.
300mm moon
