30MM or 50MM prime on a 1.6 crop?
Discussion in 'Photography Beginners' Forum' started by sinjans, Dec 19, 2009.
  1. sinjans
    sinjans TPF Noob!
    Jun 29, 2009
    346
    Newfoundland, Canada (yes by')
    I may not be going full fram for a few more years yet and i am getting a prime very soon. Should I aim for the 50mm or the 30mm. either will be a 1.4. maybe canon/sigma. But for standard portraits with the 50 being the equivalent of 80mm. would one be better off with the 30mm equaling 48mm on the cropped 50D???
    Any advice or experience will help move me forward. thanks
  2. TJ K
    TJ K No longer a newbie, moving up!
    Sep 9, 2008
    2,093
    Sunny South Florida
    If you plan on doing portraits I would recommend the 50mm even the f/1.8 is great and for 100 it's a steal. The 30mm would be better for a walk around lens while the 50 would be good for portraits with better bokeh and a bit longer as well. GL
    TJ
  3. sinjans
    sinjans TPF Noob!
    Jun 29, 2009
    346
    Thank TJ. If you were using full frame does this mean you would not use the 50 anymore? would you then jump to an 85?
  4. TJ K
    Sep 9, 2008
    2,093
    Sunny South Florida
    Ya most likely. A 50 would be just a general walk around lens and then 85 for portraits but of course there isn't just 1 lens that is the perfect portrait lens. Depends on what you want.
    TJ
  5. sinjans
    sinjans TPF Noob!
    Jun 29, 2009
    346
    Understood. Thats what i was wondering. Really as long as your shooting the equivalent to an 85 then. Thats fine by me, and i realize that my lens length preferences may vary but as a general prime i was initially curious if people with crop bodies should be using teh 50 equivalent meaning a 30mm lenses. Cheers and thanks
  6. c.cloudwalker
    c.cloudwalker TPF Noob!
    Jun 15, 2009
    5,394
    405
    An American in Europe
    Tbh, most people I know including me stay away from the 50mm (in film or FF) as it is a pretty boring lens. Some people like their nifty fifties but it seems to be mostly because it is a cheap way to get a faster lens.
    On a crop frame, however it is a fairly nice portrait lens since it puts some distance between you and your subject. And once you get a FF body you can keep it as a back up in case you kill your preferred lens. Considering its price, it is not a big loss if you only rarely use it once you've gone to FF.
    You might want to get a used one. There seems to be plenty of them around.
  7. sinjans
    sinjans TPF Noob!
    Jun 29, 2009
    346
    Yeah i will be buying used. the canon 50mm 1.4 seems to be the way to go. Sigma makes a nice one too. But i just wanted to be sure that it would'nt be too long. cheers
  8. TJ K
    Sep 9, 2008
    2,093
    Sunny South Florida
    just spoil yourself and go for the 50 1.2 :lol:
  9. sinjans
    sinjans TPF Noob!
    Jun 29, 2009
    346
    :drool:
  10. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Set your lens to 30mm and start shooting without changing the focal length. See how it feel outdoor or indoor (in terms of field of view). Now, set it to 50mm and do the same thing.
    Regardless the aperture, which focal length you think is better suit you?
  11. molested_cow
    molested_cow No longer a newbie, moving up!
    Jul 3, 2004
    3,645
    469
    Here N There
    50mm a boring lens? Well I used to think like that, but it my all time favorite lens now. There's so much you can do with it. It's really versatile and great depth of field range.
    I really don't like the term "equivalent" when describing what cropped sensors do to lens. It's basically a cropped photo. It doesn't change the performance of a lens, say from a 30mm to 50mm. You are basically limited on how you can compose your shot.
    I'd suggest you rent the lens from some place to find out if you like them before making the purchase. It's all up to your personal preference.
  12. sinjans
    sinjans TPF Noob!
    Jun 29, 2009
    346
    Thanks.
    When i say equivalent I am referring to the cropped photo. When you see so many people using the 50mm and raving about it, its nice to know if they are using crop sensored bodies or not. Because if they are on crops, then the full frame equivalent would be a 30mm. Im just making sure my ducks are in a row here. 50 1.4 here i come.
    Thanks for the help people.
30mm or 50mm prime
30mm vs 50mm prime lens
30mm vs 50mm prime
30mm vs 50mm lens
30mm or 50mm
50mm crop body angle of view
50mm on crop
50mm on a 1.6 crop
for portrait 30 mm vs 50 mm crop
what is 50mm on 1.6 crop
