3200 speed black and white?
Discussion in 'Beyond the Basics' started by davidquillin, Mar 16, 2006.
  1. davidquillin
    davidquillin TPF Noob!
    Mar 9, 2006
    18
    I had someone give me a roll of 3200 speed black and white. What would this film be good for? Thanks
  2. selmerdave
    selmerdave TPF Noob!
    Nov 30, 2004
    454
    Brooklyn, NY
    City scenes at night in low-light conditions.
    Dave
  3. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    3200 film is VERY sensitive to light. Therefore it is useful in situations where you don't want to use flash, but do want a proper exposure, and it is dark.
    It is very grainy, or noisy and your images will be very grainy.
    Rob
  4. Soocom1
    Soocom1 TPF Noob!
    Feb 27, 2006
    533
    Southwest US
    3200 speed film is good for low light conditions as mentioned above, as well as stop motion if used properly. You wont be able to photograph a speeding bullet, but you can stop cars speeding by, catch fast action, etc. When used properly, it can also give off a wonderful retro-look. It can be 'pushed' to 6400 speed for even greater effects, but needs a faster apature.
    3200 speed does have one inherent flaw. As stated above, it is VERY sensitive to light. That also makes it VERY sensitive to heat, and x-rays. DO NOT PUT IT IN CHECKED LUGGAGE!!! Do not leave it in your car, and it is best handeled until fully developed in low light or total darkness.Similar to IR film. When developed, follow the reccomeded directions EXACTLY, otherwise you will have film that will look 'burned'. Best to keep it in a sealed container in the freezer until you are ready to use it, but give it several hours to thaw out to prevent condinsation which can be deadly to it.
  5. Lensmeister
    Lensmeister No longer a newbie, moving up!
    May 1, 2005
    1,489
    14
    This blessed plot, this earth, this realm, this EN
    I once shot a set of portrait type shot of my wife. She had my black bikers jacket on and it was against a grey background.
    I also had a fairly stong light on her so it almost blew out the image. But it came out well.
    Well I liked it and so did she. ;) (it's a bit big sorry)
    [​IMG]
  6. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    What brand is it? There is actually no such thing as ISO 3200 BW film (at least on the regular market). If you read the fine print you will find that it's probably ISO 800 to 1000, but designed to react favorably to a 2 stop push with the right developer.
    I would say use it for anything where you desire grain.
  7. Lensmeister
    May 1, 2005
    1,489
    14
  8. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    Read the tech pub on Tmax 3200. Notice they put a "P" in the name somewhere. The "p" stands for push. The only difference between then and now is that it used to be "Tmax 3200p", and now they call it Tmax P3200."
    If you read the Ilford literature you'll find a similar situation with Delta 3200. Fuji Neopan 1600 may be the fastest BW film available, although I notice they recomend shooting it at ISO 800 outdoors, and ISO 1250 for certain developers, so they too may be exaggerating the number so they can put a big number on the label.
    Tmax 3200p is ISO 800 in regular developers, and ISO 1000 in Tmax developer. Here's a link to the tech pub, and what it says about exposing Tmax P3200.
    http://www.kodak.com/global/en/prof...3.18.16&lc=en#kodakprofessionalt-maxp3200film
    The "great latitude" that Kodak touts is pretty much similar to what you'd get with any modern film underexposed a stop.
    Obviously there are people using these films at ISO 3200 and higher speeds with great results. I just feel like the manufacturers are sort of playing marketing games with us by labeling ISO 800 to 1000 film at 3200; would we pay as much for ISO 800 film as we do for ISO 3200 film? ;) I've experimented quite a bit with Tmax 3200 and Delta 3200, and I've found that I prefer the results I get when I push Tri-X or develop it in Diafine. Low light photography with high speed films is definately an area where personal testing is going to be important. What works for one photog, may not be the best for the next.
3200 film speed
3200 speed film
3200 asa black and white film
3200 black and white film
best 3200 speed film
pushed tri x or delta 3200
t-max p3200 shot using iso 1000 setting
uses for 3200 film
using 3200 speed film
what is 3200 film
