Helen B
- Joined
- Sep 16, 2007
- Messages
- 3,296
- Reaction score
- 467
- Location
- Hell's Kitchen, New York
- Can others edit my Photos
- Photos NOT OK to edit
If those slides are from WWII they are almost certainly Kodachrome, and only reasonably high quality scanning is going to do them justice - not just because of the quality of the film but also because of the historical significance of colour images from WWII.
Unless you go to something like an Imacon or a drum scanner, the Nikon 5000 is likely to be your best choice, with or without a batch scanner. Batch scanning may not give the best results for each slide, but it will save a lot of time if the mounts are in reasonable condition.
Kodachrome has an unusually high maximum density (ie the blacks are blacker than almost all other slide films) and hence many lesser scanners have difficulty getting good shadow detail.
4000 ppi is the minimum that I would conside scanning Kodachrome at, and the Nikon 5000 manages to get a true resolution around that value. Not many consumer scanners achieve their stated optical resolution. Kodachrome does benefit from scanning at a higher resolution than 4000 ppi, but scanners that can actually achieve that are expensive.
Best,
Helen
Best,
Helen
