35mm SLR Lens on a DSLR Body
Discussion in 'Digital Discussion & Q&A' started by MPowerM3, Mar 19, 2006.
  1. MPowerM3
    MPowerM3 TPF Noob!
    Mar 19, 2006
    239
    Ct, USA
    Can it be done? I have a 35mm SLR Canon Eos Rebel Xs, I also have a Promaster telephoto lens. I would like to buy a DSLR (I was looking at a Nikon, cant remember the model) camara but would like to know if I can use my telephoto lenses on that camara. Sorry for the noob question. TIA
    Nick
  2. duncanp
    duncanp No longer a newbie, moving up!
    Nov 15, 2005
    3,390
    43
    Sheffield
    if the lens is a canon EF fit it will work with any canon DSLR, any lens used on a DLSR (unless especially made for a DSLR) will work as long it is the right lens fit, all that will change is the focal length as many DSLRs and all current Nikin DSLRs have a focal length conversion rate of around 1.4x - 1.8x. due to the size of their sensor.
    hope this helped
    ... the lens that fits ur canon would not work with a nikon DSLR i think.
    duncan
  3. MPowerM3
    MPowerM3 TPF Noob!
    Mar 19, 2006
    239
    Ct, USA
    So if I buy a Canon DSLR body, I can use all the lenses I have now?
  4. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    You apparently may have to send some away to get them chipped so the camera recognises thm but after that they should work.
  5. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Yes. There are adapters also I believe for using Canon lenses with other bodies, but you might lose AF and metering.
can i use a canon 35mm lens on a digital slr
can i use my canon 35 millimeter lens on canon dslr body
does a promaster camera lens fit any dslr
does a promaster fit on a nikon
len canon 35mm lenses fit dslr
pro master lens 80-210 mm fit on which camera body
promaster lens for dslr
what dslr cameras will a promaster lens fit on
will canon lenses from a 35mm camera fit a digital slr
will promaster lens fit digital rebel
