35mm too tight, need wider lens
Discussion in 'Nikon Lenses' started by maggie83, Jul 16, 2017.
  1. maggie83
    maggie83 TPF Noob!
    Jul 16, 2017
    7
    I've been the owner of a d3400 and 35mm lens (both refurbished) for about a week. I'm still learning the settings, but I can already tell that the 35mm is a bit too tight and isn't as wide as I was expecting (still gives me some great pictures though). What's a good budget-friendly lens that would well with wider shots? (For instance, turning to someone in the car next to me and taking their picture) I've been using point and shoots for years, so a lens with zoom isn't really a concern of mine...just something a little wider.
  2. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,671
    8,121
    Iowa
    Define 'budget lens' in terms of money.
    For some, $100 is a 'budget-buster'. For others, $10,00 is pocket change.
  3. maggie83
    maggie83 TPF Noob!
    Jul 16, 2017
    7
    Well considering that I bought the lens and camera refurbished, "budget friendly" is more on the side of $200-150 or less. :)
  4. qmr55
    qmr55 No longer a newbie, moving up!
    Jul 6, 2016
    312
    102
    Philly/NJ
    Ignore my response I think my head is screwed on the wrong way today :allteeth:
  5. 480sparky
    Mar 8, 2011
    22,671
    8,121
    Iowa
    Is auto-focus a requirement? If not, there's where you could save a boatload of cabbage.
    • Like Like x 1
  6. astroNikon
    astroNikon 'ya all Bananas I tell 'ya Supporting Member
    Aug 15, 2013
    13,297
    3,232
    SE Michigan
    I think OPs definition of wider than 35 would be 28, or 24 or 18mm. Not 50 or 55 as the widest.
    The kit lens is a 18-55mm VR lens which generally used go for less than $150 and would work in the situation you mention.
    • Like Like x 1
  7. qmr55
    Jul 6, 2016
    312
    102
    Philly/NJ
    Good catch, I can't read lol
  8. goodguy
    goodguy Been spending a lot of time on here!
    Dec 5, 2012
    5,542
    1,113
    Toronto Canada
    Nikon 18-55mm used should be under 100$
    A lens I would recommend is the Sigma 17-50mm 2.8, its a bit over your budget and its a great fast and sharp general use lens, worth the extra cash when bought used, this is a lens I would feel comfortable to shoot a wedding with on my D3300 if I had to.
  9. snowbear
    snowbear TPF Noob! Supporting Member
    Dec 9, 2006
    13,049
    4,631
    SoMD
    If you prefer primes, a 24mm or even used 20mm might do well
  10. Braineack
    Braineack Been spending a lot of time on here!
    Jun 17, 2013
    11,427
    4,430
    NoVA
    ask the paparazzi.
    find a cheap 18-55mm VR. You should be able to find one well under $100.
  11. maggie83
    maggie83 TPF Noob!
    Jul 16, 2017
    7
    I've looked into a 24mm, but there's a lot of them out there, and I'm still trying to understand what works/doesn't work with my d3400. Will it still be wide enough on my camera? B/c I was under the impression that the 35mm would be a great wide-angle, and it turned out too tight for my taste.
  12. astroNikon
    Aug 15, 2013
    13,297
    3,232
    SE Michigan
    for simplicity, you need "AF-S" identified lens for full AutoFocus compatibility on your D3400.
    AF/AF-D will *not* AutoFocus, they require a motor inside the body, which are only on the d7x00 series and higher cameras.
    so a few examples of Nikon lenses
    24mm => Nikon 24mm f/1.8G AF-S ED Nikkor Lens
    20mm ==> Nikon AF-S NIKKOR 20mm f/1.8G ED Lens
