3_2 4_3 o 16_9
Discussion in 'Photographic Discussions' started by danisat, Dec 6, 2017.
  1. danisat
    danisat TPF Noob!
    Oct 11, 2017
    23
    Which is the best to take photo or film that least deform a person?
  2. jcdeboever
    jcdeboever TPF Supporters Supporting Member
    Sep 5, 2015
    13,692
    7,164
    Michigan
    I would think the lens would have more of an impact. Anything from 50mm or longer should be safe.
    • Agree Agree x 2
  3. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,560
    8,089
    Iowa
    If you're referring to the aspect ratio of the image, it has nothing to do with distortion unless you're resizing the image in only one direction. In that case, you should crop instead of resize.
    • Like Like x 1
  4. Designer
    Designer Been spending a lot of time on here!
    Apr 13, 2012
    16,089
    4,028
    Iowa
    Regardless of the print aspect ratio, the focal length of your lens and how close you are to your subject is what determines distortion. To minimize distortion, use a longer focal length lens and stay well back from your subjects.
  5. KmH
    Apr 9, 2009
    40,355
    5,510
    Iowa
    Also, the camera you are using generally has aspect ratio (image rectangular shape) limits.
    Square is a 1:1 aspect ratio.
    Full size and APS-C size image sensors are 3:2 aspect ratio, but many cameras let the user use just part of the image sensor to produce 5:4 or 16:9 aspect ratio shots/video.
    As mentioned, if a image or video is shot in one aspect ratio and you desire to use it at a different aspect ratio you have to crop the original to the aspect ratio you want, not resize. Cropping involves cutting off and discarding some amount of the image pixels.
  6. danisat
    danisat TPF Noob!
    Oct 11, 2017
    23
    Thanks
    My camera have an sensor like 4:3 and a lens 24/720 which do you think so is the best position "mm" to keep pictures of persons with little distortion...?
  7. 480sparky
    Mar 8, 2011
    22,560
    8,089
    Iowa
    I'm assuming it's a typo and your have a 24-70.... so I'd say 70mm. Many pros use longer focal lengths; 85mm, 100mm, 135mm, even 200 and 300mm.
    Aspect ratio has nothing to do with perspective distortion.
  8. KmH
    Apr 9, 2009
    40,355
    5,510
    Iowa
    Yep. For the least distortion the longer focal length, so 70 mm if your lens is a 24-70 mm zoom.
  9. danisat
    danisat TPF Noob!
    Oct 11, 2017
    23
    It's a compact camera Sony:) and have 24/720 mm lens
  10. weepete
    weepete TPF Supporters Supporting Member
    Oct 18, 2011
    4,133
    1,276
    Glasgow, Scotland
    As others have said, generally the longer lens used the better the person looks, so go as long as you can. For portaits U like the 3:4 aspect ratio.
  11. danisat
    danisat TPF Noob!
    Oct 11, 2017
    23
    :05.18-flustered:
    • Funny Funny x 1
  12. weepete
    Oct 18, 2011
    4,133
    1,276
    Glasgow, Scotland
    Yeah, that U was meant to be an "I". Damn phones ! ;)
best cameras
news
