45 degree angled shots.
Discussion in 'Photography Beginners' Forum' started by Thru_These_Eyes, Nov 11, 2008.
  1. Thru_These_Eyes
    Thru_These_Eyes TPF Noob!
    Jun 11, 2007
    138
    Ann Arbor, MI
    Can anybody show me an example shot that they have, where the light is used at a 45 degree angle? Thank you!!
  2. tirediron
    Jul 8, 2005
    40,884
    12,415
    Victoria, BC
    Do you mean a studio light for a portrait, or sunlight out of doors, or ???
  3. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    45° from which axis? Left, right, up, down, coming or going?
  4. Thru_These_Eyes
    Jun 11, 2007
    138
    Ann Arbor, MI
    Its a project from school and its from the lighting section of my unit....We have not yet got into studio lighting, so I am assuming I would be outside and I also assume there is no specific left, right, up or down I should be using. I guess I am just wondering if there is a noticeable difference in photographs taken outside when the angles of sunlight changes.....I took some shots when it seemed like the sun was at 45 degrees and then again when it went down a lot more and the only thing that seemed to change was the background....im lost on this project and its the only one i have left in this unit before i can move on and ive been stuck for a few weeks...which is why i come here in hopes for some inspiration.
  5. JodieO
    JodieO TPF Noob!
    Dec 1, 2005
    255
    6
    Maryland, USA
    I'm guessing that they probably don't mean 45 degrees from "top to bottom" but more a 45 degree angle to a subject from the side. For instance, plant your subject so that the light is at a 45 degree angle to the right - 45 degrees should give you nice light that shadows a little across the face, but also isn't flat.
  6. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    Is this what you are after?
    [​IMG]
    Been kinda grey today and rainy - no sun, so I used a flash indoors at ~45° camera right and slightly higher than head height.
    *Hmmm........ ponders to self at self*
  7. DRoberts
    DRoberts TPF Noob!
    Apr 18, 2008
    780
    Springfield, Missouri
    Here ia a diagram of a 1 light set up at 45 degrees/right. Usually when describing this setup you will also add the height of the camera.
    The harshness of the light determines the amount of shadow that will be cast. The harsher the light the darker the shadow. Shadows will fall to the right of the subjects nose as well as the right cheek. This setup is often suplemented by a soft light from front to just left.
    Besides effect, this setup is sometimes used on "overweight" subjects to give a slimming effect to the face.
    [​IMG]
  8. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    heres a really neat site where you can move the light around and see what its going to do... they do it in "time count" but 45 degrees would be either 7:00 or 5:00 depending on whether you wanted left or right..
    http://www.lowel.com/edu/foundations_of_lighting.html
  9. William Petruzzo
    William Petruzzo TPF Noob!
    Aug 22, 2008
    635
    Washington DC
    That site is really cool. I wish I had that when I was getting started.
  10. chrisburke
    May 25, 2007
    2,107
    no kidding eh
  11. Village Idiot
    Mar 20, 2008
    7,274
    406
    This uses two lights that are a little more than 45 degrees from the camera. It's probably more like 60. It was just a little test I was doing. The flashes are on the left and right of the camera and they were spaced accordingly so they could light the model and not produce and glare on the windows from the reflection of the lights.
    [​IMG]
  12. Thru_These_Eyes
    Jun 11, 2007
    138
    Ann Arbor, MI
    Thank you guys for all the help and examples! I'll post up some of the pics I get after I am done and see what you guys think! Thanks Again! =)
45 degree angle photography
45 degree angle picture
45 degree angle in photography
45 degree angle for a self photo
45 degree in shot of photography
45degree shot
how to take a picture at a 45 degree angle
photograph shot from 45 degree angle
show me a 45 degree angle
what is mean by 45degree angle photography
