50mm compared to 18-55mm
Discussion in 'Photography Equipment & Products' started by camera boyy, Aug 17, 2009.
  1. camera boyy
    camera boyy TPF Noob!
    Jan 15, 2009
    6
    SoCal
    I've been looking at lenses and I noticed that the price of a 50mm lens is a lot more than a similar 18-55mm zoom lense. What's the benefit to having a 50mm lens opposed to a 18-55mm lens? Are there specific pictures that it works better for?
    Thanks for the help!
  2. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    The 50mm is probably (most likely) faster, as in an f/1.4 or f/1.8 range while your 18-55 is probably an f/3.5-5.6 or so.
    This makes the 50mm better in low light and a shallower depth of field... oh, and nicer bokeh most likely.
  3. Montana
    Montana TPF Noob!
    May 27, 2008
    1,533
    Eastern Montana
    Depending on which 50mm prime you are looking at......faster, sharper, better out of focus background qualities....perhaps better build.
  4. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Check out some of the review site such as photozone.de and slrgear.com. Read the review on both lenses. You will see some main differences between the 2.
    In general, cost of the lens is higher when it has one of more of the following factors.
    Better build quality
    Better optical quality
    Faster autofocus
    Wider maximum aperture
  5. camera boyy
    Jan 15, 2009
    6
    SoCal
    Thanks for the help! I appreciate it
  6. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    203
    Canada
    Despite any advantages of the 50mm vs the 18mm to 55mm lens, the important issue is focal length. A 50mm prime is the equivalent of 75mm on a crop body. Great for portraiture but limited in close, inside shooting.
    On the otherhand the zoom is 27mm to 78mm in 35mm terms. I use the 27mm focal length a lot more frequently than 75mm or 78mm.
    skieur
  7. robertwsimpson
    robertwsimpson No longer a newbie, moving up!
    Aug 3, 2009
    2,471
    30
    West Palm Beach, Fl
    I have both
    both are great for different things.
    18-55 is a great all purpose walk around lens.
    50 is great for portraits or low light
difference between 18-55mm and 50mm lens
difference between 50mm and 18-55mm
difference between 50mm and 18-55mm lens
difference between 50mm and 55mm lens
difference between 50mm lens and 18-55mm
difference between 50mm lens and 18-55mm lens
difference between 55mm and 50mm
what is the difference between 50mm and 55mm lens
what is the difference between a 50mm lens and a 18 55mm lens
whats the difference between a 50mm lens and a 18-55mm lens
