50mm for Landscape?
Discussion in 'Photography Beginners' Forum' started by wmc1117, Jun 23, 2009.
  1. wmc1117
    wmc1117 TPF Noob!
    Aug 21, 2008
    105
    I was just curious if its impractical to use the 50mm f/1.8 for landscape shots. I know it is primarily used for close ups and portraits but just wondering what peoples thoughts are? If not let me know what people do find themselves using it for the most?
  2. redtippmann
    redtippmann TPF Noob!
    Aug 19, 2008
    706
    6
    Athens, Ohio
    its good if you don't use a f/stop of 1.8 you shouldn't go that low because only a small portion of your image will be in the DOF.
    I use mine for low light situations
  3. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    I use my 50mm f/1.4 for low-light and portraits, but with portraits I usually stick to around 2.5 as my low point. That 1.4 is just for really low light.
    What I'm confused about is, why would you want to uses a normal focal length for landscapes? You can get a whole lot more landscape with a wide-angle or ultra-wide-angle focal length like 24mm or even 17mm.
  4. kundalini
    Jul 18, 2007
    13,603
    1,932
    State of Confusion
    The 50mm can be a fantastic lanscape use, given the right scene. It's sharpest at f/4, but very good to f/8. With a "vista" type of shot, this should not be an issue.
  5. kundalini
    Jul 18, 2007
    13,603
    1,932
    State of Confusion
    Those focal lengths may not be in his bag. :er:
  6. musicaleCA
    May 23, 2009
    2,303
    Vancouver, BC
    Point, I wasn't trying to knock the 50mm for landscapes. Prime lenses are damn sharp, I just really prefer to have a wider-angle lens to take in more of the scene. It can let you easily place stuff in the foreground too to add some interest. Just my $0.025 though (that's right, two and a half cents, just to be devious :p ).
  7. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    To OP:
    Of course, you can use 50mm lens to take landscape shot. Or you can even use telephoto lens.
    A lot of people use wide or ultra wide angle lens for it, but there are some great landscape photos I saw in the past were taken with longer focal length lens.
    I remember I read a book (forgot which one) demonstrate how, in some case, the composition of a landscape scene is better with a telephoto than a wide angle lens.
  8. LarryD
    LarryD TPF Noob!
    Feb 6, 2009
    614
    Mojave Desert
    A 50mm is fine for landscapes if you are positioned properly..
    Typically, on today's cameras, the 50mm lens will give you a smaller field of view than it might have with film cameras....something along the lines of what an 80mm lens would have.. This means that your landscaped will reflect that difference.
  9. DScience
    DScience No longer a newbie, moving up!
    Apr 12, 2009
    1,513
    122
    Denver, CO
    Well your suggesting lenses that he (or she) probably does not have which is why the OP are asking if a 50mm will work. He was not asking what's the 'best' lens or a 'better' lens for taking landscape shots.
    However, to the OP: I have a 50mm 1.4 and I think it has potential to take great landscape shots, as I have taken several that I was very pleased with.
  10. kundalini
    Jul 18, 2007
    13,603
    1,932
    State of Confusion
    This was a dicussion of 50mm f/1.4 vs f/1.8 but check out post #16 by Sw1tchFX.
    Clicky
  11. musicaleCA
    May 23, 2009
    2,303
    Vancouver, BC
    I believe you're refering to crop sensor frames, and in that case it only applies if the lens was designed for a full frame sensor and you're sticking on a crop frame body. If the lens was designed for a crop frame (like Canon's EF-S lenses, say on a 40D or Rebel) then there is no crop factor, and thus the FoV is the same at equal focal lengths on a full frame body with lenses designed for full frame sensors (say, and EF lens on a 1D).
  12. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,261
    I use a Sigma 10-20mm 4/5.6 for my landscapes on my crop-sensor camera. I find it gives me the best overall shots and an appropriately wide angle to really capture the "vista". I often find that a tighter zoom doesn't really capture the feel... but that depends on what you want to focus on.
    Another trick to keep in the bag is that you can take multiple overlapping shots with the 50mm and stitch them together. This is a bit more work, but gives you an INCREDIBLY sharp image which is also appropriately wide to meet your landscape needs (and also has a lot of pixels if you want to print an image the size of a grayhound bus with crazy level of detail) :)
50mm for landscapes
50mm lens for landscape photography
50mm fixed landscape
50mm for landscape photography
50mm landscape
50mm landscape photography
50mm for landscape
landscape photography 50mm prime lens
landscape with 50mm
