50mm lens vs. 30-70 mm lens.. pros and cons?
Discussion in 'Beyond the Basics' started by Pasternak, Aug 6, 2003.
  1. Pasternak
    Pasternak TPF Noob!
    Jul 28, 2003
    41
    I was out shooting the other day and I had some shots that I wouldnt have minded zooming in a little to take. If I had a 30-70mm lens would that have all the functionality of a 50mm lens plus zoom feature? or does the zoom make the functionality too much different than a set lens. Thanks
    Thanks
    Ben
  2. dlc
    dlc TPF Noob!
    May 14, 2003
    293
    Indianapolis IN
    The zoom will incorporate the 50mm, but is it worth it for a 2X zoom. I think that the 35-70 zoom is the most worthless zoom on the market, plus you are sacrificing lens speed that you may need sometimes. If you are in reasonably good health, zoom with your feet. The 50mm is a better lens optically anyway.
  3. doxx
    doxx TPF Noob!
    Aug 4, 2003
    499
    behind the viewfinder
    a 28-70 or 24-70 would be a common zoom lense. Sure you would be more flexible than with a plain 50mm lense. You can zoom from wide-angle to 'light' tele...
    Depending on how much cash you have to burn the zoom will be somewhat slower (higher aperture) and the image quality will mostlikely not as good as the 50mm prime. But it also depends what you want to shoot...
    look here for some listings http://www.photo.net/ezshop/category?category_id=7
30-70mm lens
30-70 mm lens
30-70 mm
30-70mm lens
30-70 mm lens explained
canon 30-70mm lens
lensa 30-70
lensa canon 30-70mm
