5DM2 in manual mode
Discussion in 'Photography Beginners' Forum' started by fliptongue, Jun 27, 2010.
  1. fliptongue
    fliptongue TPF Noob!
    Jun 27, 2010
    new york
    Should I ignore the exposure meter in manual mode while shooting with a flash??? I did a dark indoors party shoot with the 5DM2, 24-70, and a 580EX2 on a CB Junior. I set the flash to +2, shutter sync (below 200), zoom, and shot in manual mode and got results I was very happy with. But the exposure meter was constantly off and I just had to rely on my instincts. So should I ignore the exposure meter? Or am I just making a classic noob mistake?
    Please help!
    thanks,
    Flip
  2. KmH
    Apr 9, 2009
    39,019
    5,235
    Iowa
    If it's not broke, don't fix it.
    If you were pleased with results, what more could you ask for?
    Well, it would help if you understood why, from a technical point, your results were in fact pleasing to you.
    If it was just dumb luck, you need to hit the books and learn how exposure works when using strobed light, so you can recreate those shots at will.
  3. fliptongue
    Jun 27, 2010
    new york
    I would love to hit the books! Can you recommend any? It was not all dumb luck as I was able to recreat the shots as the evening got darker and darker. I just payed attention to how the pictures looked and histogram, instead of the Canon exposure meter. I'm just curious if INDEED the Canon exposure meter in the viewfinder is NOT supposed to compensate for readings with flash. Anyways, would love your advice on books!
    thank you,
    Flip
  4. Village Idiot
    Mar 20, 2008
    7,274
    406
    It's not. It exposes for the scene and then the flash calculates the proper exposure. What you were getting was very little ambient light and almost all the exposure from the flash. If you were to want to balance out ambient with the flash, you're meter as normal and have your FEC set to 0 or maybe +1/3
  5. Boomn4x4
    Boomn4x4 TPF Noob!
    Mar 15, 2010
    766
    4
    Ohio
    When shooting with a flash, you can pretty much ignore your meter (assuming you are shooting TTL) The flash will only fire as long as it thinks it needs to to correctly expose the shot. The meter only knows what its looking at BEFORE the flash fires... It has no idea what the exposure will be after. When using your flash as a fill, then you can use your meter as a guess... but when your flash is doing most of the lighting, your meter will be pretty much useless.
  6. Village Idiot
    Mar 20, 2008
    7,274
    406
    Not really. The meter allows you to tell how much ambient is in the scene and adjusting your FEC allows you to control how much of the exposure in the scene is in the flash.
    Say for instance, you're shooting in an environment with a typical light bulb that creates a warm color temperature and you want to over power it because for some reason, you don't have a CTO gel, you'd use your meter to kill the ambient exposure and the flash would expose the shot accordingly based on the reading in the camera and what your FEC is set to.
  7. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    The camera displays the meter reading for the ambient light, not the flash. So if most of the light in your photo will be coming from the flash, then you don't need to have the meter at or near the --0--.
    But if you do want to try to balance the ambient with the flash, then you can consult the meter.
  8. pbelarge
    pbelarge TPF Noob!
    Feb 11, 2010
    2,680
    New York
    Flip
    Try looking at this google page for some references.
    Google
  9. fliptongue
    Jun 27, 2010
    new york
    thanks guys! that's exactly what I wanted to know!
5dm2 how to meter
5dm2 wedding photography
5dm2 manual
5dm2 bulb
canon 5dm2 exposure meter off
how to 5d m2 camera meter reading
how to fix exposure in life mode on cannon 5dm2 youtube
how to use 5dm2 manual mode?
manual mode what to meter off of
