.5x wide angle lens.
Discussion in 'Photography Equipment & Products' started by Deadeye008, Jun 1, 2007.
  1. Deadeye008
    Deadeye008 TPF Noob!
    Apr 24, 2007
    532
    Utah
    I was wondering if anyone can tell me what the affects are of attaching a .5x wide angle lens to another lens, lets say my canon 50mm f1.8 II. Besides the fact that it makes it a 25mm lens, are there any other affects that it has on the lens? For example does it change the aperature or the sharpness or anything? Thanks:wink:
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    It will certainly affect the quality of the image. The light now has to pass through and be affected by the 'filter/adaptor'...which probably isn't made for as high a quality as the 50mm lens is. It will probably introduce a lot of distortion and the corners especially will probably be much softer than if you had used a 24mm lens.
    These things are made primarily for 'digi-cams' that have built-in lenses...and therefore can't go any wider than they are made to. If you have an SLR, a big advantage is that you can take off the 50mm lens and put on a 24mm lens.
  3. Deadeye008
    Apr 24, 2007
    532
    Utah
    Thanks!
