6x7 and 6x6 in one camera?
Discussion in 'Medium Format & Large Format' started by jonahr, Oct 8, 2008.
  1. jonahr
    jonahr TPF Noob!
    May 31, 2008
    55
    Is there any camera that can shoot both 6x7 and 6x6 or rather has compatible 6x6 and compatible 6x7 backs?
  2. compur
    compur No longer a newbie, moving up!
    Mar 6, 2008
    2,994
    497
    L.A.
  3. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    Or an RB/RZ with masks, or a GX680
  4. jonahr
    jonahr TPF Noob!
    May 31, 2008
    55
    is it difficult to find masks for an rb67 or rz67, cause i was actually seriously considering either of those cameras? and also, is there any loss in quality, and do you waste space on the film because you'll be advancing a back made for 6x7 but only shooting 6x6, (do you still only get 10 frames on a roll of 120, rather than the 12 frames which you get with a 6x6 back)
  5. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    If the camera film advance is fixed to work only at a 6x7 space then it with be the same, but if it is a free winding style when you just need to figure out the number turn you need for the 6x6 spacing
  6. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    As far as I am aware the Mamiya 67 series only comes with two back formats: 6x7 and 6x4.5.
    Bronica made a 6x6 camera that you could get a 6x4.5 back for.
    The difference between 6x6 and 6x7 is marginal so you would do just as well to use a 6x7 and mask off for 6x6 in the viewfinder - which is what pros always used to do. Then you crop when printing.
    Cheaper and easier.
  7. lomomagix
    lomomagix TPF Noob!
    Sep 17, 2008
    13
    The Bronica GS-1 has 120 & 220 backs for 6x7, 6x6 or 6x4.5. It also has available backs for 135 Normal (24mm x 36mm) and 135 Panoramic (24mm x 69mm). Of course, it also has the Polaroid back.
  8. Hertz van Rental
    Nov 8, 2004
    16,738
    46
    Where am I now?
    So it did. That's one I missed. Thank you.
    I see it was only discontinued in 2002 so good condition examples should be easy to find.
