8 and 10 stop filters
Discussion in 'Photography Equipment & Products' started by poker_jake, Apr 5, 2012.
  1. poker_jake
    poker_jake No longer a newbie, moving up!
    Dec 1, 2011
    319
    53
    Duluth, MN
    I purchased a Hitech 8 stop ND filter and it seems to cast a bluish haze over the photo and mutes the colors.
    Here's an example of an unedited raw converted to jpeg:
    [​IMG]
    Do all 8 or 10 stop filters do this or can someone recommend a filter that doesn't require a lot of pp? I have ps cs5 and it still produced a decent final result but I'd like to get it right in camera.
  2. Trever1t
    Trever1t Been spending a lot of time on here!
    Dec 30, 2010
    9,151
    2,571
    San Jose, CA
  3. analog.universe
    analog.universe TPF Noob!
    Apr 16, 2011
    1,923
    330
    Vermont
    I use the same filter as Trever, and it can be slightly magenta, but really just barely. I always shoot RAW, so a couple clicks on the tint clears it right up. The filter you're using seems to have reduced your contrast quite a bit, which is likely due to inferior coatings flaring.
    Your optical path is just like any other piece of engineering, only as reliable as the weakest link... So, best to get a filter manufactured to at least the same standard as the lens you're mounting it on.
  4. analog.universe
    Apr 16, 2011
    1,923
    330
    Vermont
    (Also, I noticed you shot this at f/22.. stopping the lens down this far will produce diffraction. This is what's responsible for the overall softness of the photo)
  5. KmH
    Apr 9, 2009
    38,770
    5,165
    Iowa
    Not all filters, ND or otherwise, are created equal.
    I've never been impressed with the quality or consistancy of Hitech filters. They are inexpensive for a reason. They are resin (plastic), not glass.
    I stuck pretty much to B+W and LEE for filters and expected to pay $100+ for any type of filter. B+W 65-073102 77mm Neutral Density 0.9-8x Filter #103
  6. poker_jake
    Dec 1, 2011
    319
    53
    Duluth, MN
    Thanks, I purchased it from b & h for $140, it's a 4x4 for my holder. I guess I may have to look into a lee or b + W
  7. zamanakhan
    zamanakhan TPF Noob!
    Sep 2, 2010
    473
    29
    mine doesn't do this at all, its an almost impossible to notice purplish tinge but its slightly there. that may be due to the camera not being able to tell WB with such a filter. But mine is a 77mm B+W filter, not a square filter.
8 stop nd filter
8 stop or 10 stop nd filter
8 stop nd
8 stop filter
b w 65-073102
b w 65-073102 77mm neutral density 0.9-8x filter phto samples
b w 77mm 3.0 nd mrc 110m filter on tokina 11-16
b w 77mm 3.0 nd mrc 110m filter vs. nd110
hitech 8-stop vs 10-stop
lee vs hitech filters
