80-300mm lens. What is the magnitude of zoom it would offer?
Discussion in 'Beyond the Basics' started by Sash[DSL], Jul 24, 2004.
  1. Sash[DSL]
    Sash[DSL] TPF Noob!
    Jul 20, 2004
    121
    A friend of mine is offering a 80-300mm zoom lens at a good price for a 35 mm camera. Im not a total newbie, i kinda know how zoom lenses work, however i have one thing bugging me: afaik, the general rule for zoom lenses is that the magnitude of zoom = max foc. length/min foc. length or something like that. However, something tells me that the image projected at 80mm is 1.6 times bigger than the 50mm foc. length that is considered "normal" for 35mm cameras. So, 1.6*(300/80) is 6x zoom. Or is it 300/80=3.75
  2. jadin
    jadin The Mad Hatter
    Feb 18, 2004
    1,740
    9
    Down the Rabbit Hole.
    Can I ask why would it matter?
  3. Goofup
    Goofup TPF Noob!
    Feb 21, 2004
    141
    Middle of Oklahoma
    I would take your camera body over to your friends house and put the zoom on your camera. This will show you the two most important things:
    1- Will it even work with your camera?
    2- You can actually look through the viewfinder and see if it will do what you need it to- and that's all that matters, right?
  4. Sash[DSL]
    Sash[DSL] TPF Noob!
    Jul 20, 2004
    121
    jadin
    It matters because I already have a zoom lens, its 1.6x zoom. It is a very good all-purpose zoom lens, BUT when i try to take candid shots of people, its zooming ability is just not enough, I still have to be pretty close to the person to take a good portrait shot. If the zoom on 80-300mm is 3.75x, it will definitely be much better, but still not good enough. If its 6x, that will mean I can take a portrait pic from across the street, which will be much handier
    Goofup
    Yes, the lens does fit the camera, i saw it on the camera and looked through the viewfinder, its fine. It would really take me a while to see if it would do what I need to do, and the seller needs to sell it either to me or some1 else ASAP. HOWEVER, I have seen people work with 6x zoom digital cameras, and it did quite a good job. I do realize that its hard to compare digital to 35mm beccause of different resolutions of CCD sensor, but im pretty sure 6x will get me what I wANT. 3x wont do it.
    SO WILL SOME1 PLEASE JUST TELL ME IF ITS 3.75 or 6X
  5. photobug
    photobug TPF Noob!
    Apr 19, 2003
    1,562
    4
    Pasco, WA
    It's still 3.75x, whether it's on a film camera or on a digital SLR.
    1.6 = digital SLR "crop factor"
    80mm x 1.6 = 128mm
    300mm x 1.6 = 480mm
    480mm/128mm = (drum roll please) 3.75x
    To get towards a 6x zoom you're looking at something in the 24-135mm range, or the 28-200/300 super zooms.
    Bear in mind that as a general rule of thumb, anything over a 3x zoom ratio on a SLR (particularly digital) isn't considered a good idea for anything but snapshot type photos.
    You have to decide what you're using the lens for. I have a 18-35mm zoom, 28-75mm zoom and a 70-200mm zoom. All less than 3x zooms. I wouldn't use the 18-35 or the 70-200 for portraits. Nor would I use the 70-200 to shoot indoor architecture shots. That would be where the 18-35mm would fall to use.
    So, saying a 6x zoom will suit your needs may not be true, if it's a 100-600mm and you want to shoot portraits. See what I mean?
    hth :)
  6. Goofup
    Goofup TPF Noob!
    Feb 21, 2004
    141
    Middle of Oklahoma
    It doesn't seem to matter what the zoom RANGE is, it seems you're more interested in how close it will get you- how many mm's do you need to get 6 times closer.
    I'm thinking that if 50mm is "normal", then 50X6 or 300mm is 6X, so whether it's a 50-300mm, 100-300mm, etc., it makes no difference- it's got to get out to 300mm.
    But thats for a film camera. If your shooting digital the CCD or CMOS sensor probably magnfies that by 1.6, so in effect, with a 300mm lens you get (as photobug pointed out) 480mm. You should have no problem getting close enough with that- if you have enough light to keep at least a 1/500 shutter speed due to camera shake.
    Now, about WhateverX zooms. I have a Z1 with a 10X zoom. That works out to 38-380 zoom lens. It still only goes out to 380mm(!) and yes, I can't hand hold it when it's zoomed out.
    Bottom line: like I suggested- if you look through the viewfinder and 300 won't get close enough for you, you need to get a 500 or 600mm lens (but I think a 300 will do you just fine).
  7. jadin
    Feb 18, 2004
    1,740
    9
    Ahhhh, I get it. I was thinking of it as purely a magnification thing, not a zoom amount thing.
    :: redawns thinking cap ::
  8. molested_cow
    molested_cow No longer a newbie, moving up!
    Jul 3, 2004
    3,645
    469
    Here N There
    Also you got to check the Aperture range it offers. If it's small, then you will be limited when you try to take picture in lowlight condition, then you will have to bring your tripot very often.
    Ones with large F range costs a bomb.
  9. Sash[DSL]
    Sash[DSL] TPF Noob!
    Jul 20, 2004
    121
    jadin
    Happens :D
    molested_cow
    Yes I realize that. I thought youd need a tripod anyway with anything beyond 200mm...
    Goofup
    Yes I tend to think that the lens is 6x... What about the 1/500?? Does this apply to 300 or 480 mm? Are you trying to say anything slower will be blury? If so thats no good, I barely encounter light intense enough to hold it at 1/500....
    photobug
    You got me wrong, the 1.6x I was talking about was the min foc. length of the lens which is 80mm/normal 50mm foc length, which happens to match the SLR->digitalCCD magnification factor
    WHY??? What do u mean by the zoom ratio? The max foc.length/min foc. length? Is it all because of low max aperture?
    Im glad for you. :D
    Why not?
    What does that have to do with zoom ratio? Isnt that because of wider angle?
    Like I said, I mostly need high zoom for candid ppl shots+nature shots. Was at a lake yesterday, with 80mm zoom I still had to get pretty close to the geese/gulls to get a decent shot.
    No :D Id appreciate it if you put a little time into explaining this a bit deeper, you do sound like you know what youre talking about.
  10. photobug
    photobug TPF Noob!
    Apr 19, 2003
    1,562
    4
    Pasco, WA
    Ah, you were talking lens magnification, and I was talking zoom factors. Two very different things indeed. :)
    On to your specific questions in response to my last post:
    Re: 3x zoom factor- Asking a lens to have a large zoom range and still be sharp would be an extremely expensive proposition. It could be done, if you had scads of money and a very large person to carry it for you. Zoom lenses are, generally speaking, already less sharp than prime lenses. Larger zoom factors just make the situation worse. Aperture does play a part, though less than moving all that glass around inside the lens to accomodate widely different focal lengths. Light does strange things when you move lens elements through large distances. How critical is extreme sharpness to your needs? Maybe not at all.
    Re: Why not?- the 18-35 would distort the persons features if you got close enough to them for them to fill the frame. The 70-200, while at the smaller end would work for portraits, the thing weighs 2.5 pounds. Not something I'd normally hand hold for a portrait. Maybe 25 years ago, but not now. ;)
    Re: Isn't that because of the wider angle?- Yes, that's why I'd use the wide angle there, has nothing to do with the zoom ratio. I was illustrating the point that you need to fit the focal length of the lens to the task. Zoom ratios were irrelevent to that portion of the discussion. Sorry for the confusion.
    Re: I had to get close... - and this brings us back round to fitting the lens to the task. A 80mm lens (zoom or not) will fill the frame (on 35mm film) with a human head and shoulders from aproximately 6 feet shooting distance or so. To fill the frame with a goose, which is roughly the size of a human head & shoulders, you'd have to be at the same 6 foot shooting distance.
    To increase the shooting distance and still fill the frame you'd need a longer focal length lens to fill the frame. What focal length is determined by the size of the subject and the distance you want to shoot at. Now you're getting into lens magnifaction factors. This post will either explain it, or totally confuse you.
    In the case of the 80-300mm lens in question- at 80mm it would have a 1.6x magnifaction factor. At 300mm it would be a 6x magnification factor. It sounds like the 80-300mm should fulfill your needs for a all-around portrait/nature lens.
    Oh, I wasn't bragging about the lenses, I was using them to illustrate my point. :)
  11. Goofup
    Goofup TPF Noob!
    Feb 21, 2004
    141
    Middle of Oklahoma
    The Rule Of Thumb is that you need a shutter speed of at least 1/focal length if you're handholding the shot. In other words, your natural camera shake would be magnified (in our case) 6 times, so a faster shutter speed (1/500) is needed keep the picture sharp. (That's why telescopes are sold with tripods).
    All is not lost. With proper bracing or proping against anything handy you can safely shoot at a slower shutter speed.
  12. Sash[DSL]
    Sash[DSL] TPF Noob!
    Jul 20, 2004
    121
    I see. Do you know of a technical reason why this happens? Inacuracy of element positioning within the lens? *Unaccounted for* light refraction instances?
    Does this mean that a 50-80mm would be sharper than 35-80?
    Oh and I read that post u gave a link to, skimming in through the formulas of course - Im no shape for math in the middle of the night. :) Basicaly all said makes sense to me especially since you already answered my question. Theres one thing that bothers me though:"internally focusing lenses loose focal length when you focus closer." So if you have 50mm prime it actually zooms out when you focus on something close?
    Goofup
    Yes its funny because I am totally aware of the rule of thumb (why is it called that btw?), it just didnt click when you mentioned it :|
    How much lower? Can you go 1/45 with an 80mm(suppose u use tripod)
    By the way I noticed that if you hold the camera with your left hand(holding the elbow against the belly) while strapping your right hand to the right side of the camera tight with the strap and gripping it firmly, it does get pretty steady if you hold your breath. But i am still planning to get a tripod...
80-300mm
80-300mm how much zoom
80-300mm lens
300 mm to feet
300mm = feet
access camera lens 80-300mm
how many feet is 300mm
lens 80 -200m equal
what does a picture look like at 55mm and 300mm
what is possible with a 80-300mm lens
