9 exposures with D7000
Discussion in 'Nikon Cameras' started by Psytrox, Aug 15, 2014.
  1. Psytrox
    Psytrox TPF Noob!
    May 29, 2011
    145
    13
    Norway
    Hi,
    I have the D7000 and the firmware for some reason, beyond all reasoning is limited to 3(!!) exposures. Go NIKON!
    I've been looking at various methods to get around this issue, one being to use the U1, U2 function. Which involves touching the camera, which I naturally want to avoid. The other being to buy that ridiculously expensive promote controller.
    Is there any software that would work with either a Windows phone, or iPad that would be able to control the camera, and set up say 9-12 exposures? Is there a PC Software that could do this? Also if people have any experience using either of these it would be greatly appreciated :)
  2. astroNikon
    astroNikon 'ya all Bananas I tell 'ya Supporting Member
    Aug 15, 2013
    12,080
    2,930
    SE Michigan
    I don't really do HDR because I've been able to do this type of look directly in LightRoom. Though, I don't do it often.
    I did find this, which, as you have mentioned due to the restricted 3 shots you have to touch the camera. In the comments someone describes what you want but it requires U1, A, U2 settings ---> Shooting HDR with the Nikon D7000 - Sumptuous Art
  3. Braineack
    Braineack Been spending a lot of time on here!
    Jun 17, 2013
    10,190
    3,899
    NoVA
    Why arbitarilly 9-exposures? why not take as many as you need to achieve full dynamic range of the scene?
  4. Psytrox
    Psytrox TPF Noob!
    May 29, 2011
    145
    13
    Norway
    Well, the exact amount of exposures was beside the point. My question really is if anyone knows of a PC/iPad or Windows phone software that will let me do more than 3 exposures. My camera firmware is limited to 3 exposures, which doesn't always cover everything. There is also no unofficial firmware for my camera either that will allow me to do more than 3 exposures.
  5. Braineack
    Jun 17, 2013
    10,190
    3,899
    NoVA
    I'm trying to find a video for you, where the bracketing method uses 1/3 stops until you achieve full DR of the scene and you only combine those. The results from this method of true HDR looks much better than the arbitrary +1/0/-1EV method, and it makes much better sense IMHO.
  6. D-B-J
    D-B-J Been spending a lot of time on here!
    Apr 13, 2010
    9,027
    2,172
    That's one reason I HATED the bracketing feature on the D7000. Three frames is nearly useless.
  7. Rick50
    Rick50 Been spending a lot of time on here!
    Jan 7, 2013
    3,066
    1,017
    San Diego, CA
    Right, Just switch to full manual control and do this.
  8. lambertpix
    lambertpix No longer a newbie, moving up!
    Sep 27, 2013
    938
    368
    Columbus, OH
    Triggertrap mobile can do this, but only for "long" exposures (approx 1/16 and longer) -- presumably because it can't trigger fast enough for faster shots? Anyway, here's a review w/ some info: Triggertrap Mobile 2.0 | Shutterbug
  9. KmH
    Apr 9, 2009
    39,017
    5,235
    Iowa
    As mentioned you can always use M mode and 1/3/ 2/3 stop exposure steps with a 2 second shutter timer delay to let the camera settle between each manually made bracket.
    See page 214, Custom Settings Menu - c3 of your D7000 user manual
    You might want to consider using the D7000's Interval timer with U1 and U2.
    See pages 155 to 158 of your D7000 User Manual.
  10. hamlet
    hamlet No longer a newbie, moving up!
    Sep 12, 2013
    2,881
    426
    Belgium
    I personally use photomatix, photoshop cs6 & cc. You can pretty much blend however many exposures you want with any of the programs i mentioned. I once did 32 different exposures to see what i would get.
  11. Braineack
    Jun 17, 2013
    10,190
    3,899
    NoVA
    what's the point of blending 32 if it only took 2 to achieve perfect blacks and whites?
  12. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    21,729
    7,752
    Iowa
    Use your U1 and U2 modes to accomplish 9 frames.
