A couple of dumb PS question
Discussion in 'Graphics Programs and Photo Gallery' started by Dmitri, Aug 2, 2008.
  1. Dmitri
    Dmitri No longer a newbie, moving up!
    Jun 20, 2008
    5,879
    39
    End of the line
    #1: I save my images as Raw + JPG. I just noticed that when I open a RAW file it opens the image at 3888x2592 pixels (which it shows at 16.2 x 10.8 inches). When I open a JPG it opens at 3888x2592 pixels (which is shows at 54 x 36 inches!). So first dumb question is: Should I be worried about what it says for inches, or pixels? Otherwise it seems I would get better quality from JPG when I crop?
    #2: When I crop an image and I set the values for the crop manually (say 12 x 8 inches), I do this force an 'aspect ratio' for printing. My question is: When I manually set my crop width and height like that, am I forcing a resample that I probably don't want? Would it turn an otherwise larger image smaller, or smaller to larger?
    Thanks.
  2. rufus5150
    rufus5150 TPF Noob!
    Mar 8, 2008
    1,658
    Austin, Texas
    For #1 - your resolution for your RAW files is whatever your import program (camera raw?) is set to. Likely 240? Off the camera, the jpegs will be at 72. (240/72 = 3.33, 3.33 * 16.2 = 54 so I'm guessing 240 and 72 are the ppi resolutions).
    For #2 someone else will have to answer definitively because I don't crop this way, but my feelers say you're probably forcing a resample that you don't want and/or don't have terribly much control over.
  3. Dmitri
    Jun 20, 2008
    5,879
    39
    End of the line
    Does this make a difference? Should I change my RAW settings to 70 then, or 300 even? Or is it the pixels that matter more than the ppi?
    Crud, that's what I thought. Have to find a new way to do the ratio thing then.
    Thanks for the words, Rufus.
  4. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    Quality-wise just worry about pixels. If you are getting different inch measures for the same pixel count it just means that the ppi is set differently for the different file types. Ppi is just scale.
    I'm pretty sure the only way Photoshop would resample your image is if you have the Image Size window open, and you've got the resample image box checked.
  5. Dmitri
    Jun 20, 2008
    5,879
    39
    End of the line
    Aaah ok, that sets my mind at ease. Thanks man.
    Again, thanks for the info. :)
