point-&-shoot
- Joined
- May 21, 2010
- Messages
- 291
- Reaction score
- 0
- Location
- bay area ca
- Website
- www.flickr.com
- Can others edit my Photos
- Photos OK to edit
i was kinda debating over the background. i started with something close to what you did. i got my inspiration from a member of calguns.net, jeffu. he edits his and thet look something like mine but even better. im just trying to figure out what he does.
i've figured out that its more than lighting effects in cs3.
Nice looking weapon. I'm not a fan of the lighting though. It's not terrible, but there are lots of shadows on your background which detract from the image I think. Also, the backgrounds could use some more light on them, or mask and bring up the white in post.. they look a little gray.
#1 looks good except for the shadows and the off-white backdrop imo. I wonder what it would have looked like if you lit it from camera left as well.
I'm not feeling #2. The depth of field trails off and leaves the rear of the rifle blurry. There's also a weird warm color cast back there. Did you use different types of lights? It helps a lot if all the lights are the same color temp, less to fix in post anyway.
EDIT:
This is what I was thinking should be the goal. Maybe it's not the look you were going for, but then why use a white background?
Not going to go into great detail about the edit because I used a Photoshop plugin called Viveza, but I did create a layer to work on, brightened it up and then erased the gun from that duplicate layer.
