A few Ducks
Discussion in 'Nature & Wildlife' started by 250Gimp, May 13, 2008.
  1. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    Here are a few shots of some mallards I took this morning.
    The light was a bit low as I was trying out my 70-200 f4 plus 1.4x TC, so was actually shooting at f5.6. Some were shot on a monopod....something else I am trying to learn.
    Let me know what you think.
    1) [​IMG]
    2) [​IMG]
    3) [​IMG]
    4) [​IMG]
    Thanks in advance :D
  2. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    Bump
  3. Overread
    May 1, 2008
    24,072
    4,172
    UK - England
    I like that you are really trying to get low down angles on the birds (even if in some cases you simple can't - without getting very very wet)
    hmm you appear to be getting quite a lot of glare on the whites and reflective areas of the mallards - that first is fine, but the others in the direct light are suffering a little = you could try fixing this by selective reduction in brightness on the shots or by shooting in RAW mode and then lowing the exposure a little.
    After that these shots seem a tiny bit soft yet I think the originals were sharper - do you apply any sharpening (unsharpen mask) after you resize for the web? If not then I would suggest you do as it can restor some lost sharpness in a shot
    the only final point I can make is that in similar conditions you might try underexposing a little more - if you look at the last show the female in the shadow of the male is not suffering from the glare that the male is.
    Nice shots but I think you can get better results with a little more practise
  4. 250Gimp
    250Gimp TPF Noob!
    Oct 3, 2006
    1,031
    Chelsea, Quebec
    Thanks overread!
    I will try your idea of underexposing a bit.
    TO be honest the shots didn't seem that blown out when I was editting them.
    I don't think I resharpened after the resize. I will try that as well.
    Cheers
