Firstly, is that one of your shots?
So what about this image do you like? What do you want to do in Photoshop? To me, it looks like this one has very little processing done to it.
Firstly the photo is high-key. Meaning the majority of the frame is white. The difference is simple. You were shooting down on Rita. Looks like the camera level is about tip of the head-high. In the linked photo the camera appears to be chest / shoulder high shooting up. That changes the perspective a bit (more flattering in my opinion).
Ok now as for the post processing here's an attempt. You didn't specify if your pictures are ok to edit so just pm me and I'll remove this
The image on the right was converted to black and white using the channel mixer with 100% red, 0% green and 0% blue.
This gives the skin a flatter colour, removes blemishes, and brightens the skin while darkening the hair. Then the curves tool was used to remove mid-tone contrast, and darken the shadows.
Now share the lighting you used, Flash or reflector?
If you click the spot in the upper left hand corner called User Cp and then click Edit Profile you will find at the bottom of that page the place to enable the 'it's ok to edit'.
I have used here a plug-in for photoshop by Alien Skin called Exposures. The film I mimicked is Ilford 200SFX
High-key means the majority of the frame is bright with some defining features darker and standing out, like in my edit the hair, eyes and dress. The opposite effect is low-key and an example low-key shot would be this self portrait http://farm1.static.flickr.com/208/4...864e4dc8_o.jpg.
You photo is already high-key to a degree with the main subject standing out from a light background, just that I personally find the background wasn't light enough. It wasn't a distraction though so it didn't matter too much. If you would have shot from a slightly higher angle the entire background would be sand, or from a lower angle the entire background would be sky which would be blown to white or close to it.
There's no rules for using the channel mixer as such it depends on each photo. If the subject has some dark skin and you are trying to bring out the defined nuances like wrinkles it may help to give a lot of weight to the blue channel. If you a photographing a red-head it may also help to bring the blue and green up a bit to prevent the hair going bright white when making a black and white picture. Red and green also darkens blue skies, but if you want to lighten the sky it would help if you use a bit of blue. It really depends on the picture.
Sure go for your life. I'd be happy to comment. Post them here or PM/email me or both.
Also the reflector is good, but the small size has created a very defined shadow of her nose on the left which is possibly distracting, but inevitable given the equipment. I use a similar sized home made one and often make similar shadows .
Also there is a second catchlight in her right eye which could be photoshopped out.
I think the first and third phots are good, but the second one, i think the background is a bit distracting
No no no. The key of a photos just describes the light. I just applied it to your specific situation above. You were shooting at a beach in the first photo right?
You have sand on the floor, something like trees a fence possibly in the middle, and a sky above. To make it more high-key you remove the dark trees / fence in the middle. It has nothing to do with how low or high you shoot. I only said that because if you were on your knees shooting upwards you would have only sky in the background which would be white.
Or if you shoot down from a ladder you'd only have sand in the background which would also be white.
The Levels and curves tools are very similar with curves being much more powerful with a steeper learning curve.
One other thing is the background is just as important as the foreground. The lighting is least of the problem in the 2nd image. The background is a mess, and the front on shot is plain boring. But I guess it was a snapshot anyway
The 3rd one is much better. The pose is interesting, the background is far less distracting. The edit looks better too. Still a tad too much contrast if you are aiming for an image like hayakuhei's edit. Her skin may be a tad on the darker side and blends in a bit wit the rest of the image.
One other thing. You mentioned you may want to go back and change things you can adapt this workflow using layers. When using curves levels, channelmixers or other image adjustments rather than doing it form image -> adjustments click the add adjustments layer in the layers palate.
I do not do portraits... Don't know why... just don't. But I have to say that you have access to some really pretty and very natural "Girl next door" Models.
