A Red Rose - help please
Discussion in 'Photography Beginners' Forum' started by Ronaldo, Aug 28, 2010.
  1. Ronaldo
    Ronaldo TPF Noob!
    Aug 28, 2010
    85
    13
    Any help that can be given to do the following would be greatly appreciated.
    I would like to take a picture of a red rose:
    - straight on down at it (that is, not at any angle but right into the flower)
    - capturing the whole flower in the frame, without anything cut-off
    - as sharp as possible
    - with as much red color saturation as possible
    - and with as much "3d" effect as possible
    Leaving any artistic issues aside, what are the optimal conditions, equipment and technique to try and "perfectly" capture the rose.
    I will probably be doing this with a Nikon D90. So given that, what lens would be best, lighting, settings, set-up, etc.
    If I did have my choice of camera/lens for the optimal pic - - what would that look like (within reason :).
    Thanks!
  2. Ronaldo
    Ronaldo TPF Noob!
    Aug 28, 2010
    85
    13
    hmmmm - - bump
    Any recommended books or websites that might best explain how to do this?
    thanks
  3. DanFinePhotography
    DanFinePhotography TPF Noob!
    Aug 13, 2010
    680
    Redmond, OR
    I personally have found that to get the results i am after i have to experiment with my own settings, conditions etc. You should go to your local florist pick the best looking red rose you can find take it home and arrange it in many different ways. Possibly put a black backdrop behind it and a little bit of lighting or try window lighting if its available. Every book your read or website you visit the techniques of each author is going to vary slightly due to each authors own opinion of how things should be done. Take a thousand photos of the rose or as many needed until you get the results you want. Write down different settings that work best for you.
  4. Morpheuss
    Morpheuss TPF Noob!
    Jul 4, 2010
    596
    South Carolina
    i personally would just try it and do it different ways with holding it strait up and it doesn't seem like it would be that interesting photo
  5. Ronaldo
    Ronaldo TPF Noob!
    Aug 28, 2010
    85
    13
    Yeah - - this is for a specific project. I'll surely do a lot of experimenting. But I'm also trying to cut down on the time it takes - - so am hoping to find out what others have done and learn ahead of time. Maybe avoid some common mistakes, etc. And maybe get some good ideas. thanks
  6. Bitter Jeweler
    Bitter Jeweler Been spending a lot of time on here!
    Apr 27, 2009
    12,984
    4,971
    Cleveland, Ohio
    :thumbup:
  7. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    Is this something like what you want to do?
    A Rose is just a Rose. | Flickr - Photo Sharing!
    (Not mine)
    The rose is not red, but you get the point.
    I just did a search for 'rose' on Flickr... Lots of examples. Many of them have the exif data, so you can see what settings & camera/lens they used.
    (To see the exif, click on the 'Actions' tab and select 'View exif'.)
    I don't think it would really be very hard... All you would really need is a tripod and a lens of a suitable focal length. A flash might be helpful too.
  8. Ronaldo
    Ronaldo TPF Noob!
    Aug 28, 2010
    85
    13
    Thanks.
  9. Ronaldo
    Ronaldo TPF Noob!
    Aug 28, 2010
    85
    13
    thanks
