- Joined
- May 1, 2008
- Messages
- 25,421
- Reaction score
- 5,000
- Location
- UK - England
- Website
- www.deviantart.com
- Can others edit my Photos
- Photos OK to edit
A focus stacked image made of 10 frames.
Each frame taken at: f8, ISO 200, 1/200sec with flash in ettl mode.
Setup; camera was setup in a manfrotto focusing rail on top of a manfrotto junior geared head all mounted on a set of tripod legs (might also be manfrotto ).
For lighting I used a 580M2 with a lumiquest softbox held above the insect as well as white paper placed below the insect and the twig it was on so as to bounce light up into his face from the flash so as not to darken the underside too much.
I stacked the image using CombineZM of which I know about 3 commands of - new stack, stack image, save. So there is a lot left to learn about this program as yet.
Well overall the final image is better than I expected, though I feel like I want to now have more frames for more depth, I focused on his face too much and missed the edges and his legs a little which is a shame I think. Also I used a rather small aperture for this sort of work - I could have shifted to a wider aperture, but I didn't want to add more complexity to this setup for an early try so stuck to a reliable aperture. If I do open up the aperture I can also then remember to lower my ISO though honestly the image from CZM already has pretty minimal noise.
An interesting point (and one which is a pain as well) is that CZM seems to brighten the final image quite a bit, this has led to problems with another image stack I did where the whites on the ruff of the moth have been near blowout in the original images (red channel too hot it seems) but the final stacked image has a clear blowout of the ruff. I might have to set the exposure to negative values in RAW editing to correct this problem or there might be a command in CZM to reduce or counter the effect.
Overall I think the shot worked, but I would be interested in hearing others views on the image and on CZM as well
Any comments/crits welcome - thank you
