A summer's night sky
Discussion in 'Landscape & Cityscape' started by crawdaddio, May 21, 2006.
  1. crawdaddio
    crawdaddio TPF Noob!
    Dec 5, 2005
    1,157
    14
    Central IL
    There is a little noise, but I don't think it's too bad for my first attempt at a long exposure with digital.
    D50
    24-120 lens @ 24mm
    30 minute exposure (I've since learned that this is the D50's max. Dangit!)
    f/22
    ISO 200
    focused at infinity
    [​IMG]
  2. PlasticSpanner
    PlasticSpanner TPF Noob!
    May 1, 2005
    4,125
    51
    Cheshire, England
    At what time of night did you try this? Did the D50 set or tell you the aperture or was it your own choice? Seems a bit small for a star trail shot!
    Still works quite well though, even with a blue sky!:thumbup:
  3. crawdaddio
    Dec 5, 2005
    1,157
    14
    Central IL
    It was just after dusk. About 8:30 p.m. I set the aperture manually. Should I be using a larger aperture?
  4. TTPeter
    TTPeter TPF Noob!
    May 11, 2006
    221
    30 min not long enough? lol
  5. Raymond J Barlow
    Raymond J Barlow TPF Noob!
    Jan 28, 2005
    5,136
    149
    Grimsby, Ontario Canada
    good try, for the first time.. I would forget about my camera, and fall asleep if I tried this!
  6. LaFoto
    Feb 1, 2004
    34,814
    816
    Lower Saxony, Germany
    Ah Ray, that is from chasing cute little birdies all day long in all sorts of environments which makes you so tired then.
    So what was the exposure time you went for for these, craw daddy --- erm ...? :wink:
  7. crawdaddio
    Dec 5, 2005
    1,157
    14
    Central IL
    ^ I wanted 45 min. to an hour Lafoto. I was hoping to get some real long star trails.
    Thanks everyone, I'll definately be trying this some more.
  8. PlasticSpanner
    May 1, 2005
    4,125
    51
    Cheshire, England
    Done that! :lol:
    Idealy you want an apeture 1 or 2 stops down from your max. But if there is still daylight you'll over expose the sky! :confused: Best to try it at the darkest hour of the night.
    If you want a longer exposure than 30 secs then set the camera for a double exposure on a remote release! :thumbup:
  9. crawdaddio
    Dec 5, 2005
    1,157
    14
    Central IL
    ^ From the max? You mean max like the 1.8 on a 50mm 1.8? So about f5.6 or f8? Won't that let too much ambient light in? Thanks for the pointers!
  10. PlasticSpanner
    May 1, 2005
    4,125
    51
    Cheshire, England
    Yep.
    The larger the aperture then the more stars you'll capture.
    But you will need a dark, unpolluted sky.:(
  11. crawdaddio
    Dec 5, 2005
    1,157
    14
    Central IL
    Therein lies the problem. I will keep at it though, thanks again:)
