crawdaddio
When using curves or levels for contrast only, you need to set the layer mode to luminosity. Otherwise you will (might) inadvertently adjust the color scheme. To adjust color level (saturation, brightness) individually, I have found that the selective color adjustment layer works better than hue/saturation.Aegina said:Thank you so much for your feedback and no, it's not your monitor, the green is too vivid, and the colors of the background a little bit pale, this is due to the Photo Shop work. I don't know exactely why, but when I work with the contrast, levels and curves in order to change a little bit the background, to change the contrast, the green part of the photo gets like this. Any suggestion regarding the third photo is more than welcomed. Thank you very much! And thanks for the first photo Still, just one more question Doesn't the right corner of the first photo seem a little bit burnt (it was a cloudy day, dark...). Just asking
I really like the last one ALOT. Nice series.
