A Tripod Dilemma
FrankLamont
I can't really decide between the Velbon CX 888 and the Velbon CX 480.
The 888 is $20 more.
Here are the specs.
480:
Features a 2-way PH-248 fluid panhead. Light weight and ideal for compact video/8mm camcorders. Radial braced, 3-section legs. The CX-480 also features a Spirit level.
Maximum Height
147cm
Minimum Height
56.8cm
Folded Height
58cm
Weight
1.3kg
Diameter of Leg
20mm
Leg Sections
Maximum Load
5kg
888:
A new tripod in black finish, ideal for general purpose photography. It features 4 section legs and has a maximum height of 145cm.
The CX-888 has a PH-249Q fixed panhead with QB-4W quick release plate and carrying case.
Maximum Height
145cm
Folded Height
48cm
Minimum Height
46cm
Weight
1.3kg
Diameter of Leg
23.2mm
Leg Sections
4
Maximum Load
3kg
