AA batteries
Discussion in 'Photography Equipment & Products' started by Rhys, Jun 2, 2008.
  1. Rhys
    Rhys TPF Noob!
    Jan 26, 2008
    975
    Columbia, SC
    I'm looking at getting some AA rechargeables for my flashes. I have a load of NiMh batteries of about 1600 mah that are getting a bit elderly (5 years old). I'm thinking of getting low discharge batteries. I'm not keen on the price though - the ordinary ones seem cheaper and of higher capacity.
    I charged some of my exisiting batteries some days ago and one pair almost immediately didn't work, despite having been given the all-clear by a reconditioning charger.
    Given the age of my batteries, I feel new is in order. My question is thus:
    What's the cheapest price and place you've found for AA low discharge or AA high capacity and where was that place? I know my local BiLo sells low discharge AAs.
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    I've ordered batteries and a charger from HERE. They seem to be pretty good.
    As for you old NiMh batteries...A photographer that I know, was in the same position as you, with a lot of old batteries that just wouldn't hold a charge, even after 'reconditioning'.
    He found a charger that can bring these worn out batteries back to life. He liked it so much, he bought a couple of them. C-9000
  3. Rhys
    Rhys TPF Noob!
    Jan 26, 2008
    975
    Columbia, SC
    Hmm....
    $3.47 for 4 AA 2000mah by Lenmar (Chinese)
    $7.97 for 4 AA 2100mah low discharge by Kodak.
    Hmm.... I'll have to check how much BiLo is charging but that $7.97 looks very tasty indeed. I'll probably need to get maybe 10 packs.
    I already have a Maha reconditioning charger. I don't have any non-reconditioning chargers. Some batteries have just been used a lot, I guess.
  4. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    That's what I said to him...but he said that this charger was able to bring new life to these batteries when his other 'reconditioning' chargers would not.
    I think that standard reconditioning chargers just cycle the change...they drain and recharge the batteries several times. This one will slowly 'force' the charge into them. I don't know all the details...but I believe my friend Lloyd when he says it really works.
  5. Rhys
    Rhys TPF Noob!
    Jan 26, 2008
    975
    Columbia, SC
    Hmm $12.95 for 4x 2000Nimh Duracell pre-charged with 365 days battery life.
    Very interesting as that's in my local BiLo. If I only buy 2 packs then I'm fine. If I need more then even with postage Thomas Dist is better. For 2 or less packs, BiLo is better.
  6. dk148
    dk148 TPF Noob!
    May 20, 2008
    10
    VA
    Sanyo Eneloop, have worked great for me. I bought a couple of kits with chargers when costco had them on sale, and I will not buy another type of rechargeable. The problem now is finding them in stock anywhere. Circuit City had a sale on them a couple of days ago, but they were out of stock by the time I found out.
  7. Stratman
    Stratman TPF Noob!
    Jul 15, 2007
    265
    St. Louis Missouri, U S A
    Another vote for the Sanyo Eneloops, I have 2 sets of them, and they are WAY WAY WAY better than the Energizer rechargeables I have. You might also look into the Ray O Vac "hybrids" they are similar to the Eneloops, I have a set of these too, and they are very good !!
    The advantage of these is that they HOLD their charge when you are not using them. So if you have 2 sets, the one not being used will not lose its charge sitting in your bag, like MOST rechargeables will.
  8. S2K1
    S2K1 TPF Noob!
    Jul 5, 2007
    288
    Utah
    Just ordered the Sanyo Eneloops based on good reviews from Amazon. They were $12.99 for 2 batteries and a charger. Then an additional 4 batteries were $9.65.
  9. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    I don't know why those re conditioner chargers are needed for NiMh's anyway, since they don't hold a memory the way nicads do. Supposedly there is no need to completely discharge the NiMh's, and that doing so could actually shorten it's life since it's all the discharging and recharging that shorten it.
    No, I did not attend MIT.
  10. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    You would be surprised at the shape that NiMh batteries can get into. Many chargers now have a test mode, so you can test their actual capacity. Apparently, it's fairly common for them to be well below their rated capacity...even when they are fairly new. For example, I had a few 2500 mAh that would only hold about 1900 mAh. I put them through the refresh mode on my charger and they are much better now. Eventually, they do start to wear out and won't respond to charging...or even a refresh mode. That is where the C-9000 can (appearantly) bring them back to life.
    I know that they really aren't supposed to have a memory...but I always try to fully discharge them before charging them up. That is supposed to keep their capacity high for a longer time. I also try to use a lower level (longer time) charge. With he charger that I use, I can set it to discharge them at 200 mAh and then charge at 100 mAh. It does take a long time to charge them though. If I need to, I can also set it as high as 1500 mAh (I think).
  11. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    I just picked up a bunch of Sanyo Eneloops the other day from Costco. A starter kit with a charger and some batteries, and then another kit with just batteries, almost all AA's for flashes. Tried them out the other night and WOW what a difference from alkalines!
  12. Rhys
    Rhys TPF Noob!
    Jan 26, 2008
    975
    Columbia, SC
    By the time an NiMh battery gets to about 4 years old it should be pitched and replaced. I have some that are about 7 years old and am slowly putting them into the solar lights as the batteries there wear out. Currently one pair out there is getting a bit bad and they're NiMh so that's where the next pair of elderly NiMh batteries is going.
    Given the relatively low cost of AA NiMh I'm surprised to find myself bargain hunting for them. It's like petrol/gasoline - it's just an expense. In reality, even at the current prices it's not really that expensive.
