About to order Nikkor 50mm f/1.8, is it worth it?
Discussion in 'Photography Beginners' Forum' started by sarasphotos, Aug 27, 2010.
  1. sarasphotos
    sarasphotos TPF Noob!
    Jun 19, 2010
    143
    usa
    I am about to order the Nikkor 50mm f/1.8 lens. Anyone recommend it or not recommend it? Any info on it or pics you have taken with it would be great!!! thanks! I want this to be a lens I use alot!
  2. Rosshole
    Rosshole TPF Noob!
    Mar 23, 2009
    536
    14
    WI
    What do you find yourself most commonly taking photos of?
    What body are you using?
  3. sarasphotos
    Jun 19, 2010
    143
    usa
    People/portraits, Nikon D3000
  4. Rosshole
    Rosshole TPF Noob!
    Mar 23, 2009
    536
    14
    WI
    with the D3000, you will have to manually focus it, but it is a great little portrait lens!
  5. sarasphotos
    Jun 19, 2010
    143
    usa
  6. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    Correct; you will need an in-body focusing motor for it to AF, which your camera unfortunately doesn't have. That said, it is an excellent lens, and a real value for the price.
  7. NateS
    NateS TPF Noob!
    Sep 27, 2007
    2,753
    40
    Missouri
    AF = ability to focus with bodies that have a motor built in.
    AF-S = ability to focus on all bodies.
    Your D3000 has no motor in the body to control an AF lens so you need to find an AF-S lens. I would suggest a 35mm f1.8. The 35mm focal length is easier to use for more situations and it has AF-S to autofocus. Plus it isn't that much more expensive....especially if you can find a used one.
  8. AdrianC
    AdrianC TPF Noob!
    Aug 1, 2010
    155
    Edmonton
    For the d3000 you will need to buy AF-S lenses. AF lenses will not autofocus on that camera.
  9. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
  10. sarasphotos
    Jun 19, 2010
    143
    usa
    Thank you so much for the info! I guess the lens that came with my camera spoiled me to auto focus! I just thought all lens auto focused. haha I'm learning so much :)
  11. ababysean
    ababysean TPF Noob!
    Apr 29, 2010
    1,965
    103
    Pensacola, FL
    YOu can get the 35mm 1.8 at best buy. I have that lens and it stays on my camera. I also have the 50mm 1.8 but I've used it for like 2 minutes and then put it back. If you are shooting children or anything that moves, it is very hard to focus.
  12. ghache
    ghache No longer a newbie, moving up!
    Jan 25, 2010
    3,570
    295
    you should take a look at the af-s 35mm 1.8! its a little bit more expensive, but you will have the autofocus.
    you can also look at the af-s 50mm 1.4g
