Accurate Representation
Discussion in 'Beyond the Basics' started by happyhippy, Mar 18, 2008.
  1. happyhippy
    happyhippy TPF Noob!
    Jan 24, 2008
    15
    Yorshire Dales
    I have a problem :(
    I have to take photos of 150 oil on canvas paintings in 2 weeks :D.
    The photos are for an art brochure of some kind and will be printed at A4.
    For lighting I am using pollarized tungsten light and obviously a pollarizer on my camera. I will be using my newly aquired Canon 400D and the kit lens (I am saving for a new lens atm).
    My problem is getting the exposure right, I am using the camera on manual and built in light meter says 1 sec at F8 100ISO when I point it at my grey card but when I view these later it seems a bit dark. I am dubiious of ajusting them by eye as my monitor isn't amazing.
    Do you think if I incorporated grey, white and black cards somewhere around the edge of the frame and left the pictures in RAW the printers would grade it themselves? I am not sure which printer we will be usung yet so I cant ask them.
    Chears :)
  2. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    1) Why are you polarizing the light source if you've got a polarizer on the lens. The only thing that does is make you lose a lot of light. You're already losing half of it by polarizing the light source, then another fraction of that depending on the angle of reflection when it hits the polarizer on your lens.
    2) Include a calibrated color and/or gray card off to the side. White balance off the gray card pre-shot and color-balance off the color card in post.
  3. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Forget the light unless its in a place where the quality of the light is not even, even if it is VERY low.
    If it is low but even, place the camera on a tripod, use a long shutter speed and shoot away. Extra lights give shadows, if you are not good at it. ;)
    Shoot RAW and adjust WB in post processing.
  4. happyhippy
    Jan 24, 2008
    15
    Yorshire Dales
    I thought that regular tungsten light isn't polarized so the filter would have no effect?
    They want a small amount of shadow to bring out the relief.
    I was more worried about getting the brightness right so that the images look exactly the same as the painting. If I left an 18% grey card at the side would the printer be able to adjust the exposure to that? Or could I do that on photoshop?
  5. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,961
    13
    Durham, UK
    seems to me that you know little about photography have a crappy uncalibrated monitor and are about to take on a commercial shoot with sub standard equipment, printers will print what you give them, you're the tog, sort your gear and give them corrected images. H
  6. frXnz kafka
    frXnz kafka TPF Noob!
    Jul 9, 2007
    517
    Maine
    The printer is going to put out whatever you put in (maybe with come color shift, but your printer isn't going to fix your exposure).
    You don't really need a gray card, especially if you're shooting digital. I'm not going to get into the lighting, because I don't know enough about it, but just meter with the camera. If the shot looks dark on the screen, adjust your shutter speed. I think you're way over-thinking this.
  7. confucious
    confucious TPF Noob!
    Aug 16, 2007
    125
    Ottawa, Canada
    I have the same Canon you do, and I find that in full manual, center weighted, I have to underexpose a little to get the "right" exposure. IN other words - the Camera always says I am underexposing by 1-2 stops...but it is always wrong ;)
    So - set your light so the art is lit how you want (for relief etc.), put your cam in manual, Raw, center weighted metering, however many autofocus points you want, ISO 100, and set your white balance for best results. Do a few at different exposures (I don't think you'll be changing Aperture, about 4 stops from max. should be the sweet spot), take them home and fix the white balance in your free camera software. Take a range of images, put them on a USB and go get them printed to see what values you like best.
    If you are doing 150, than it is worth making sure they are all done properly.
    By the way - I know this is beyond your control at the moment, but the kit lens is pretty horrible!!! A cheap Canon 1.8 would get you 100% better results!
    And of course, use a tripod and remote shutter, especially if you have to have one second long exposures!
    Good Luck
  8. CanAm
    CanAm TPF Noob!
    Mar 4, 2008
    113
    San Jose, CA
    The kit lens isn't that bad. One of my close friends has taken 4,000 photos with the 18-55 kit lens and most of them came out great.
    Also, the problem he's having has nothing to do with the lens. 1.8 is too big an aperture to take good pictures of canvases.
    I say shoot at F/8 or F/11 with camera on AV and adjust EV accordingly.
  9. confucious
    Aug 16, 2007
    125
    Ottawa, Canada
    Perhaps my kit lens was a poor representative of the rest of them, who knows ;)
    As to Aperture - I didn't suggest he SHOOT at 1.8, just that perhaps that would be a better lens for this kind of thing. The sharpness, colour, Bokeh, image period is far better with that lens, and it's cheap :) Even with the nifty-fifty I'd suggest he shoot 4-6 stops higher that wide open.
  10. JerryPH
    Oct 14, 2007
    6,111
    15
    Thats the issue, center weighted... if you are focusing on someone with a dark T-shirt of course the rest of your picture will be over exposed. You want a setting that averages out instead of focusing the metering on one small part of the pic.
  11. JerryPH
    Oct 14, 2007
    6,111
    15
    Depends for who and what your goals are. Compared to a P&S, the kit lens does well... but for someone serious about their quality, its quite lacking in sharpness and quality of output. There is a reason it is inexpensive, the quality of the glass is poor compared to a faster/more expensive lens.
    Thats not an insult, thats a fact. You cannot compare a Yugo to a Cadillac and expect the same performance or comfort.
  12. confucious
    Aug 16, 2007
    125
    Ottawa, Canada
    gaaahhhh - I am silly. Of course that's it - I never even thought of it, and tend to always leave the cam on Center weighted. So it's NOT my Camera, it's me :) :lol:
canon 400d colour representation uncalibrated
photography accurate representation
