Add other shutter lengths possible?
Discussion in 'Beyond the Basics' started by chyidean, Dec 14, 2009.
  1. chyidean
    chyidean TPF Noob!
    Dec 5, 2008
    36
    On my Nikon D90, under manual, I can select 10sec, 13 sec, 15sec, 20 sec, 25 sec, 30 sec, and finally bulb. Is there any way I can add 1 min, 2 min, 3 min etc exposure lengths (without using bulb)?
    I'm interested in getting a B+W ND110 to experiment with long-exposure photography.
  2. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    No. Longer than 30 seconds, you have to use bulb.
  3. chyidean
    chyidean TPF Noob!
    Dec 5, 2008
    36
    Okay, so if I use bulb to achieve 1sec+ shutter lengths, it wouldn't be practical to just press down the shutter button right (as there would be camera shake, may let go, etc)?
    So I'd have to get a release cord? And hold down the button for X minutes there?
  4. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Yes - a remote is the way to go.
    Wireless or wired - your choice. Wired, you hold the button down (there will usually be some sort of locking device so you don't have to actually hold it).
    Wireless, press once to open the shutter, press again to close it.
    You can just hold the shutter release on the camera down, but you have to be careful to avoid camera shake.
    Not sure about your camera specifically, but there should be some sort of timer that starts when you hold the shutter open in bulb so you know how long it's been open.
  5. chyidean
    chyidean TPF Noob!
    Dec 5, 2008
    36
    Nope, no timer on my D90, unfortunately.
  6. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Really? Are you sure?
    On my 350D, when I'm in bulb there's a counter that shows how long the shutter has been open.
    If you don't have that (that sucks), just use your watch. With exposure times that long, being a few seconds off here or there won't matter at all.
  7. chyidean
    chyidean TPF Noob!
    Dec 5, 2008
    36
    Any idea how I should be calculating the exposures? Or even better - can you direct me to a guide to long exposure photography? As you can tell, I'm a complete noob. I tried googling and most results aren't specific enough.
  8. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
  9. ecnal
    ecnal TPF Noob!
    Jun 10, 2009
    134
    Plymouth, MA
    For the record, I bought a wireless IR remote for my D40 and I LOVE IT. Paid 15 bucks on ebay for Nikon brand, but from what I've heard everywhere the cheapo $3-5 generic ones work just as good.
  10. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    They el-cheapo ones are good. They do fail but guess what, they are cheap. I have replaced mine every year, but at the rate I'm going I would need to replace them another 6 times before I've covered the cost of one Nikon remote :)
    The results for long exposures aren't specific because it's mostly guesswork. You can take an educated guess though, or take an example shot. I was in the rockies once and it had -40degC so I really wanted to take 1 long exposure, get it right the first time and then get the hell back into my hotel. My solution was to take 1 30 second exposure at ISO6400. It looked like hell but at least I knew that it was approximately twice as bright as I wanted it to be.
    30s @6400
    1m @3200
    2m @1600
    4m @800
    8m @400
    16m @200
    32m @100
    Halve the brightness: 16m @ ISO100 was my final exposure. Nearly nailed it.
    In less extreme circumstances I have just set up my camera and taken several many minute exposure to determine which one to pick.
    The logical solution would be to take a group of 30second exposures and then stack the required number together using image stacking software to create the exposure you want, but that is too much effort for what could be passed by simply spending a bit of time to guess and correct in the field.
  11. roadkill
    roadkill TPF Noob!
    Jan 26, 2008
    392
    Atlanta GA
    wireless remote. love it. 16-20 dollars.
  12. KmH
    Apr 9, 2009
    40,548
    5,543
    Iowa
    Also known as the Nikon ML-L3. $18 at B&H.
