advice for going backcountry and tripod
Discussion in 'Beyond the Basics' started by papatooth, May 28, 2009.
  1. papatooth
    papatooth TPF Noob!
    May 28, 2009
    45
    danbury ct
    howdy
    what do backcountry hikers do for carrying their camera's into the wild. i always had a digi point and shoot but i finally bought a canon digital slr. im just not sure how to approach a grab and go scenario, also what lightweight tripod could i get. i like to do generally a day or 2 out nothing more at the moment. :lmao:
  2. farmerj
    farmerj TPF Noob!
    Apr 26, 2009
    588
    I use a small [ame="http://www.amazon.com/Targus-TG-50TR-50-inch-Aluminum-Camcorders/dp/B000R4D9AC"]Targus 50" Tripod [/ame]I carried up from my Sony H9. It fits nicely inside my Backpack I have set-up for camera gear.
    It's lightweight, can handle the D90 with my 70-300 VR lens on it. Folded up, it's about twice as long as the 70-300 is stored in its carry bag and about the same diameter.
    I still plan on getting a nicer tripod, but for lugging around in the back woods and a general all-around carry piece, it does the job for me at the moment.
  3. tirediron
    Jul 8, 2005
    41,108
    12,494
    Victoria, BC
  4. Gaerek
    Gaerek TPF Noob!
    May 2, 2009
    1,341
    98
    Sitka, AK
    Might want to consider a monopod instead of a tripod for backcountry stuff. I believe there's a couple brands out there that have models that double as a walking stick or something like that. I want to get one eventually, but I haven't found a big need for it yet. I usually use my cheap (meaning light) ballhead when weight is an issue. No need to bring my heave duty gear out there.
  5. dcclark
    dcclark TPF Noob!
    Feb 19, 2009
    480
    Houghton, MI
    I use my hiking stick as a ghetto monopod -- I would never bring a real tripod, WAY too much weight, unless you're extremely serious about some nature photography. In which case, you probably have a huge lens and a good case system already. :)
    For my own packing, all I bring is my camera and the lens on it (Nikon 18-200 -- convenience is king!) It's not small, but it's much smaller and lighter than taking any more equipment, and it does pack pretty well.
  6. Mike_E
    Jan 26, 2007
    5,327
    266
    You can get a 1/4X20-1/4 screw at most hardware stores. Screw that into a nice 3/4 walking stick and it will fit your camera or a ball head to make a mono-pod.
    If the stick is thick enough you can screw one in from the side for a vertical orientation and forgo the head. Just be mindful that it's there. ;)
  7. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    I use a monopod depending on how heavy the brush is where Im going and, what I plan on shooting.
  8. papatooth
    papatooth TPF Noob!
    May 28, 2009
    45
    danbury ct
    so for the 190CXPRO4 190 MAG FIBER TRIPOD 4 SCT manfrotto what kind of head do i need
  9. Gaerek
    Gaerek TPF Noob!
    May 2, 2009
    1,341
    98
    Sitka, AK
    This is a preference thing. I prefer ballheads for the most part, but some people love pan heads. Research both, and decide which fits you best.
  10. Alerick
    Alerick TPF Noob!
    May 19, 2009
    25
    By the time I was an Eagle Scout I carried less equipment through the back woods than any other scout. If you just need a place to prop up a camera for a limited time or for night shots; why not build a tripod in the backwoods find three sturdy sticks and lash them together. Then the camera can be cradled inside the top. They are super easy to lash together and when you are done. Throw the sticks back into the woods and keep your rope for next time :)
    [​IMG]
  11. papatooth
    papatooth TPF Noob!
    May 28, 2009
    45
    danbury ct
    hi, what head do you use?
  12. vinski
    vinski TPF Noob!
    Jun 8, 2009
    39
    bozeman, MT
    I have carried large camera setups a long ways back. Video mostly but the principals are the same. Defitinity use a tripod over mono espiecially if you are going to do some LT exposures. Just look for a decent back pack. I usually make my own out of a Wookey backpack with High density foam/ and or coorugated plastic. That pack really holds a tripod (heavy ones even for video) but look into Dakine camera packs. Nice packs with waist belts (make sure most of the weight is placed on you hips, not your shoulders) They have many different sizes and such with ability to carry sticks!
    Good luck!
ways to pack in a camera and tripod into the back woods
