advice needed again
ipon
i have a job to do sat night at a bar/club with a band playing. what mode should take these pics in? thanks in advance.
There are lots of threads on here with the same sort of question, so a search will yeild some good results, but my advice would be to use your highest ISO(depending on the light, but your gonna need at least 800) and your widest aperature. I normally shoot manual, but if your more comfortable with an auto setting, use Av, so you can control the aperature and keep it open. Try to avoid using flash. Hope that helps.
thank you, i'll try to search some more..
