BrianV
- Joined
- Nov 26, 2012
- Messages
- 806
- Reaction score
- 123
- Can others edit my Photos
- Photos NOT OK to edit
If you post how far the actual focus is off at a given distance, I can compute how much the shim needs to be thickened or thinned.
It is just like the Jupiter-3: The optics module unscrews from the focus mount, the new shim goes into place, and the hard part is moving the aperture ring to line up correctly after screwing the optics back in. The Three set screws for the aperture come out, and most of the time can be screwed back in to hold the ring into place. Occasionally, you need to tap out holes for the set screws, like on the J-3. Most J-8's and J-3's: back-focus about 1"~2" at 3ft, when used wide-open. Increase the shim 0.1mm corrects 80% of them. About 2 layers of thin kitchen aluminum foil.
This is with an early Jupiter-8 wide-open, adjusted by setting the shim using the "0.1mm rule of thumb".
