Advise needed on lens
Discussion in 'Photography Beginners' Forum' started by Nightfly, May 21, 2008.
  1. Nightfly
    Nightfly TPF Noob!
    May 21, 2008
    Hi all,
    I was hoping someone could advise me as to what sort of lens I should get. I currently have a Canon EOS 300D, which I have been using to photograph houses. It takes good pictures outside but I find that the pictures inside make the rooms look small and I cannot get the whole room in. Is there a wider angle lens that would do the trick or do I need a new camera?
    Any help would be much appreciated,
    Regards
    James
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    wide angle will do the trick. with the smaller 300D sensor I would for example go for a sigma ultrawide zoom 10-20mm so you can get really wide.
  3. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    ^^^ you only have to look through a 10-20mm lens once to realize its potential at stuff like indoor photography. I also recomend you buy a flash with a head that you can point up and bouce off the cieling becuase if you use the one on the camera not only will it cast a shadow off the lens that will be in the picture, but its not wide enough to cover the whol image with light.
  4. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    It might help to know what lens you are currently using.
  5. Nightfly
    Nightfly TPF Noob!
    May 21, 2008
    Many thanks for the advice. That gives me some new things to try. I am currently using a Canon (EFS?)18-55mm. I like the flash idea as a lot of my pictures were very dark even with the flash and I have been using photoshop to fix them. Are there any flashes that you would recommend that would produce that effect?
    James
  6. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    345
    North New Jersey, United States of America
    For your canon, look into the 580EX or 430EX flashes. If you are considering used, the 550EX and 420EX flashes. These dedicated flashes are a very good start. For maximum control, look into a set of flashes and pocket wizards.
  7. JIP
    Aug 29, 2006
    3,019
    Pittsburgh PA
    Well if you are doing interior shots you might want to consider going off-camera. For things like this there are lots of corners and spaces that you can never properly get with an on-camera flash.
  8. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    I think that you guys are pointing out some great ideas but for that standpoint he is at now i think he just needs 430ex and then also look into a wide-angle lens.
    Do you have a budget or price range?
  9. Nightfly
    Nightfly TPF Noob!
    May 21, 2008
    That is a good point. I hadn't really considered my budget. The cheaper the better but I would say £300-600 for the lens and flash together. I could stretch it if it would drastically improve the quality.
