I think I understand. Which is exactly why I prefer manual, cause it gives me full control. But maybe that's just a lifetime of use of autofocusing cameras that never could never focus on what I wanted talking, hahaI use AF. But sometime i want a shot out of focus to a certain extent. Hope that makes sense
Sent from my LGMS210 using Tapatalk
Sent from my SM-G930V using Tapatalk
Single point. I've always wonder what AF was like on high end cameras. On my d3200 its funny because it chooses exactly what i dont want to focus on lol!I think I understand. Which is exactly why I prefer manual, cause it gives me full control. But maybe that's just a lifetime of use of autofocusing cameras that never could never focus on what I wanted talking, hahaI use AF. But sometime i want a shot out of focus to a certain extent. Hope that makes sense
When you say auto focus are you referring to single point AF or Auto letting the camera choose your focus point? Single point AF for wildlife has got to be better than manual focus.
That's what I'm doing.IMHO, I concur with the others.
USE your lenses till you clearly identify a need that they will not fill. Then you can make a better decision to determine if you need to buy a lens to fit that need or not.
Ill second the 35mm F1.8. Its one of the cheapest lenses nikon makes and one of my favorites. I also have the D3300.
One thing that often goes over looked by new comers is that Nikons (D3300) will accept any F-Mount lens ever made. So that means basically every lens they have made since the late 50's. The only catch is that you need to run in full manual mode (not a problem once you get used to it). With this in mind you can grab some of the old macro lenses cheaper than a new one and they will work just fine. A great deal of info can be found here and you can find compatibility info here. Great deals can be had on Ebay and flea markets if you are willing to hunt a bit.
Oh, I didn't realize that! I thought all those lenses were a different mount. (Can't remember what letter) I can manage full manual mode, I just have to take a bit more time. It's good practice and for such a deep discount (I've seen ridiculously cheap older lenses) that's definitely something I'm going to look into. Thank you for the links as well.
A nice summary that covers all the points I was going to add to your earlier post.The mount itself is the same F mount from the 1950s.
The problem is the lens/meter coupling mechanism has changed over the years from mechanical (ears) to mechanical (AI), to electronic.
And mechanical screw drive AF to electronic AF. The 3xxx series cameras cannot AF the mechanical AF lenses.
BIG caution, it is not as simple as mentioned.
There are some specialized lenses that project into the mirror box and require that the mirror be raised. These cannot be used unless your camera has a mirror lift function. Or you will crack the mirror when installing the lens.
So study the compatibility chart.
Manual Focus works for some thing, like macro, but does not work well for other things, like sport and following fast moving kids. dslrs do not have a screen that is easy to manual focus.
