AH! My negative!
Discussion in 'Beyond the Basics' started by Ghoste, Jan 20, 2006.
  1. Ghoste
    Ghoste TPF Noob!
    Dec 27, 2004
    552
    Yorba Linda, CA.
    Oh no! It got a drop of water on it and apparently wiping it is bad! It like got all sticky and smeared. Is it ruined? :(
  2. stingray
    stingray TPF Noob!
    Oct 28, 2005
    179
    as hertz has said before, lick it off :p
    if it's smudged it would seem that it's more than water... and if you live in a place with hard water then it's probably dry now and you'll have to rinse them properly once more to remove the impurities.
    hopefully that's a serious question and us newbs are not being set up to say silly things?....
  3. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    If the mark's on the shiny side, then a polishing cloth should take it off, other than that - ask Hertz or Terri I would say!! Perhaps washing in distilled water would take it off the other side, but get a more expert opinion than mine.
    Rob
  4. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    Water can soften up the emulsion again until it dries. I ruined a neg doing the same thing. I tried wiping it and ended up moving the emulsion around (it got sticky). Luckily it was in a non-detail area, so I was able to scan it and fix it in PHotoshop. I can still make digital prints, but I probably won't be able to use the neg again.
    You might be able to scan it and try fixing it in Photoshop. It depends on the detail of the area and how big.
  5. terri
    terri Administrator Staff Member Supporting Member
    Sep 2, 2003
    27,198
    2,766
    In the mental ward of this forum
    If it was on the softer emulsion side, it may indeed be compromised. You won't really know if there's true damage done until you try to make an enlargement from it. Most ugly-looking water marks have absolutely no effect on your ability to make a good enlargement, and often it's best to leave them alone, especially if they're on the dull emulsion side of the neg. Dust and particle matter is another story - they can scratch the emulsion so it's worth trying to clean dirty negatives.
    Just let it dry, resist the urge to touch it anymore, and check the print quality next time you're in the darkroom. I hope it's all right! :hug:: If that happens again, simply shake the water off and let it air dry in an enclosed environment away from dust - then inspect the negative. Chances are it will be fine. Good luck!
  6. Ghoste
    Ghoste TPF Noob!
    Dec 27, 2004
    552
    Yorba Linda, CA.
  7. terri
    Sep 2, 2003
    27,198
    2,766
    Sorry it got scratched. :( If you ever thought you'd want a print, you should probably rescan, save as a TIFF file and make whatever fixes you can in PS. You'll be able to print a decent image from a TIFF file.
