Air show
Discussion in 'General Gallery' started by my*, Mar 19, 2010.
  1. my*
    my* TPF Noob!
    Feb 24, 2007
    117
    Arizona
    I took these at the air show practice session. I need some c&c. I'm going to the real show on Sat. What can I do to improve?
    Probably will not get the mood to cooperate again, but what can you do?
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    5.
    [​IMG]
    6.[​IMG]
    7.
    [​IMG]
  2. Sam6644
    Sam6644 TPF Noob!
    Nov 18, 2009
    248
    Cincinnati, Ohio
    Pretty cool stuff. They could all use some cropping, but they're all pretty neat shots.
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Neat planes, but these are all woefully underexposed.
  4. my*
    my* TPF Noob!
    Feb 24, 2007
    117
    Arizona
    I can see what your saying. I'll have to make some adjustments. I don't know if the bright clouds/sky in the back ground was screwing things up or what.
  5. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    If you shoot in manual you can just dial it in and basically just leave it.
  6. my*
    my* TPF Noob!
    Feb 24, 2007
    117
    Arizona
    This weekend we should will have clear skys. I think with the more consistant lighting that would be a good idea
  7. Al-Wazeer
    Al-Wazeer TPF Noob!
    Dec 25, 2008
    1,174
    Bahrain (somewhere in mid east)
    Great shots, but as said above they're underexposed.
  8. SNAPaPHOTO
    SNAPaPHOTO TPF Noob!
    Mar 2, 2010
    74
    Myrtle Beach SC
    I think guys if he exposed the shots properly you would not see the moon and that adds to the pictures. I personally would bring up the exposure on the aircraft only in PS.
    The shots do need some cropping done, but other than that, beautiful shots.
  9. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    Yeah, the exposure is off in most of them leaving them too dark. But great action.
  10. my*
    my* TPF Noob!
    Feb 24, 2007
    117
    Arizona
    Thanks for your input. I'll work on the exposure. Now that I think about it my exposure may be set a 1/3 low.
  11. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Oh they're more than 1/3rd of a stop under, more like 1-2 stops. When you're shooting, make sure you check your histogram.
    the moon doesn't really add much the the images, and if the exposures are lightened up in PS, than you'll be bringing in a bunch of noise into them. like the one of the f22 level, the picture that's almost square, if that was shot at..ISO200, bringing up the exposure 2 stops is going to make the noise level like ISO 800, but there's going to be really muddy shadow areas, and a pretty lousy tonal range because all the information is pushed towards the shadows. no matter how you play it, it's no bueno.
  12. Overread
    May 1, 2008
    24,003
    4,152
    UK - England
    Also you need to experiment and see if you can find some aviation threads/forums/blogs and find out the best shutter speed for capturing the propeller action. It always looks a little odd when the blades are perfectly sharp or mostly stopped in a photo when the plane is in flight.
    You've caught the action well and with a few little crops got some good shots - but the underexposure is a problem. I've found that one has to often overexpose the image (based on the meter reading at the time) for such work where you have a bright surrounding environment and a shaded/darker main subject. Aperture or shutter priority with the exposure set to overexpose (experiment to find out the exact amount needed) should give you some better chances. Also do use the histogram as and when you can with reviewing to get a look at the exposure and know instantly if you need to adjust the exposure.
