All Digital Camera's SLR!?
Discussion in 'Beyond the Basics' started by Saeid, Dec 19, 2004.
  1. Saeid
    Saeid TPF Noob!
    Nov 9, 2004
    50
    Persian Gulf
    Ok i was thinking the other day, and it occured to me that almost all digital camera's with LCD screens are SLR.
    You are basically shooting what u are seeing on the screen. (this is course if u dont use the view finder, then again no one really does)
    Oh and im not talking about the professional digital camera's.
    what u guys think?
  2. Hertz van Rental
    Hertz van Rental TPF Noob!
    Nov 8, 2004
    16,728
    45
    Where am I now?
    What do we think about what? (puzzled emoticon)
  3. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
    In theory, yes. In practice, no. You aren't really seeing what the lens is seeing, you're seeing what the lcd is showing you. So focusing and dof preview isn't all that realiable.
    That's just my take on it though. :)
  4. DocFrankenstein
    DocFrankenstein Clinically Insane?
    Apr 29, 2004
    1,646
    6
    SLR should have a pentaprism in them.
  5. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
    That's only because the film is in the way and to convert the image so it's the correct way around though isn't it? So it's isn't a defining part of an slr really. Or am I wrong?
  6. oriecat
    oriecat work in progress
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    that's what the reflex part means. you gotta have a mirror to reflect the image through the prism.
  7. Replic
    Replic TPF Noob!
    Dec 16, 2004
    84
    You're talking a bout a prosumer camera- powerful enough to do professional shots, but not considered an SLR.
    To be an SLR, you need two things. One- the veiwfinder OR LCD must show EXACTLY what the lens sees. Electronic viewfinders on digital cameras (like my fuji finepix s7000) also show what the lens sees. So yes, LCD screen cameras could be considered SLR if they fulfill the second definition as well.
    Two- Removable and interchangeable lenses. This is where most digitals, and my own Fuji, fail to become an SLR- the lenses are set in stone and can not be changed.
  8. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
    Oh yeah. :roll: :oops:
    But it's only there because the film is in the way. So as I said, in theory yes, in practise no.
    *runs off and hides his red face*
  9. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Replic, not all SLR cameras have removable interchangeable lenses. That is not a requirement for SLR. Single lens reflex cameras have one lens that the photographer sees through and the light travels through to expose the film, or sensor, and the reflex is the action of the mirror moving out of the way when you open the shutter. A point and shoot digital with no mirror and prism is not an SLR.
    It has nothing to do with interchangeable lenses or not. Most SLR cameras have the ability to interchage lenses, but not all.
  10. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
    I think he is just referring to being able to see what the lens sees. Not the ability to change lenses.
  11. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    I was refuting this statement, which is untrue.
  12. Unimaxium
    Unimaxium TPF Noob!
    Nov 13, 2004
    2,689
    22
    Northeastern University, originally from Philly
    Technically, not all digital cameras are SLRs. The term SLR (single-lens reflex) refers to a camera whose viewfinder and capture device (film, CCD chip, or CMOS chip) use the same main lens. Since normal consumer digital cameras usually have a viewfinder that uses a different lens than the one that the CCD or CMOS does, they cannot technically be referred to as an SLR, because they do not have the reflex action that reflects the image up to the viewfinder from the main lens. However, most digital cameras do have an LCD screen on the back that shows you what the sensor is seeing through the main lens. So you can see how the subject matter will be framed in the final shot without any parallax error. And you can also get a general sense of the focusing and DOF. However, there is a limit to the number of pixels that the lcd screen can show. The sensor can capture many more pixels than the screen has, so you don't get to see all the information in the image when you look at it. This is where the advantage of a true digital SLR comes in. The viewfinder on a DSLR is basically the same as on a film SLR camera. It is optical, not digitial. With an SLR, your eye is seeing the shot without the LCD in the middle, which means you can see much more detail since your eye can see more information than an LCD would display. The advantage of this is that you can get a better sense of the focusing and depth of field when you see the shot optically than digital. DSLRs are especially useful when the camera has interchangable lenses, since then a separate viewfinder would not necessarily show what the lens is seeing, and the LCD display would not show you precise depth of field and focusing. So basically, no; technically not all digital cameras are SLRs, although in practice they kind of have a similar effect because of the LCD screen, but as you get more advanced in photography and need more accuracy in framing and focusing your shots, the separate viewfinder and LCD are not enough and you need an SLR viewfinder. I hope this clarifies the subject a bit.
