All white images?
Rayne
NY
I put my sb600 on camera and took some photos with no probelm. When I removed the sb600 to take some outdoor pictures I keep getting solid white images. Then I put the on camera pop up flash on and the images came out. Does anyone know what I did wrong and how to fix it?
I Never had this problem before.
Nikon D200
50mm 1.8
It could be happened when you was set setting as manual. First you have checked that you was not set images as white backgroud. So then you can get all the pictures in white images. So you have to set images as normal mode. Then you would be get normal picture. I wish that it could be help for it.
You have to check your camera meter - make sure that you are exposing correctly if you are in full manual mode or that you don't have exposure compensation enabled if you are shooting in the semi auto modes.
The all white is a sign that your image is overexposing - a lot - which means that your not recording any data save white. Lower the ISO, use a faster shutter speed or a bigger f number (smaller aperture)
All fixed, thank you....
