alright, what am I doing wrong
Discussion in 'Beyond the Basics' started by Battou, Oct 23, 2007.
  1. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    I have tried this three times now with different settings, all have failed. The only settings that remain constant are the film at asa 800 and the 135mm lens. Why can I not get the letters on the mountain to show up correctly when they are lit.
    [​IMG]
    (other two seen here: http://thephotoforum.com/forum/showthread.php?p=1007945#post1007945)
    Should I try a slower film, or maybe a faster shutter speed and milti expose it?
    Any suggestions would be appreciated.
  2. Chris of Arabia
    Chris of Arabia Herding cats since 1988... Supporting Member
    Mar 10, 2007
    7,825
    16
    The Magic Kingdom
    I think at its simplest level, you are just too far away from the signs to be able to avoid this sort of effect occuring. Not sure what shutter speed you're using, but if it's lengthy as I suspect it may be, you are giving lots of time for moisture/dust in the atmosphere to move in front of the lights and be illuminated. You'd then end up with a similar effect to the one you get with long exposures of moving water and the burn out you get there.
    Did that make sense at all?
  3. Battou
    May 10, 2007
    7,997
    26
    Yes it did, I am not sure witch one of the three it was but the fastest shutter speed I used was a 1/125, I'll have to dig up my log book, I thought it was in my briefcase but it's not.
    I assume that there is a way to capture something exactly as I see it or maybe closer but this is what I keep getting.
  4. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    your underexposed, try longer exposures. H
  5. Battou
    May 10, 2007
    7,997
    26
    I have I got the same burn out if not worse.
  6. Chris of Arabia
    Mar 10, 2007
    7,825
    16
    The Magic Kingdom
    Hmm, not sure. I think the distance is the main factor here, that and the relative capabilities of the old Mk1 Eyeball and a camera.
  7. Battou
    May 10, 2007
    7,997
    26
    Mk1 ?
    You could be right the other light shots I have done and got reasonably clear where much closer. Never the less, I have a three day weekend comming up and I am going to put every suggestion and thought into this subject a try. I want this shot that badly.
  8. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Yes, distance is a factor... but if you cut that distance to about half, you will find a bit of an improvement. Also the pic is not that you are underexposed, but over exposed. Your meter may read properly exposed, but you will want to not get that halo effect and see the letters clearer... only way to do that is to increase shutter speed by 1 or 2 steps, possibly 3.
    Good luck.
  9. Battou
    May 10, 2007
    7,997
    26
    Thank you, I'll give that a try as well
    unfortunately this is taken from a bridge and cutting the distance is not possable, as water and buildings are in my way:mrgreen:
  10. JerryPH
    Oct 14, 2007
    6,111
    15
    Lol... yeah walking on water may not be an option for you.
    Question, is that condensation or dust on the lens that we are seeing? It looks as if there is a lot of artifact on the picture that looks like dust or someting. Hard to tell.
  11. Battou
    May 10, 2007
    7,997
    26
    Likely debris from the scanner, I did this scan after just short of fifty some odd exparimental opentop scans placing numorous diffrent things onto the scannerbed.
  12. Rick Waldroup
    Rick Waldroup No longer a newbie, moving up!
    May 10, 2007
    743
    37
    Texas
    Is it completely dark when you are shooting this? If so, and if the letters are lit up, try shooting right around or just before dusk, while there is still some ambient light.
