alternative light meter question
Discussion in 'Photography Equipment & Products' started by myopia, Apr 2, 2007.
  1. myopia
    myopia TPF Noob!
    Oct 17, 2005
    920
    MA and CO
    i know this has been discussed before, but i could not find it in a search...
    can i use my digital point and shoot camera as a light meter for my mamiya 645 film camera? i dont see why not...
    thanks
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    If you can set (or even check) the settings manually then you should be able to use the digi-cam as a meter. If you can set the digi-cam to display a histogram, I would suggest using that to judge exposure, rather than looking at the image on the LCD screen.
  3. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    I do this sometimes when I forget my handheld meter. Obviously its important to consider the differences though, for example with my digital p&s I always set exposure compensation to -1.0 because it doesn't like highlights at all, whereas this wouldn't be such an issue with negative film. As Mike suggests I find it better to use the histogram rather than the LCD image.
  4. myopia
    myopia TPF Noob!
    Oct 17, 2005
    920
    MA and CO
    thanks a lot, i will be refering to the histogram.
