Aluminium or Carbon Fiber?
Discussion in 'Photography Equipment & Products' started by joshuatdlr, Jan 7, 2017.
  1. joshuatdlr
    joshuatdlr TPF Noob!
    Nov 29, 2016
    12
    Cambridge, England
    I am in the market for a new travel tripod, I found one that I think is really good. It is compact and has a good load capacity. The problem for me is that there are two types, carbon fiber and aluminium. Naturally the aluminium is cheaper and heavier, but I am having a hard time finding a real difference between the two, other than weight. Which one is more durable? Is the Carbon fiber one lighter and more durable, or is it just lighter? Is the aluminium one more rugged? I would like to know the differences other than price and weight.
  2. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,262
    15,117
    USA
    Cheap carbon fiber has sort of a rep for breaking. Cheap aluminum has been around for decades, and is typically, I think more durable, especially on the made in China type tripods. Again, cheap AND has a good load capacity? Sounds a bit unusual. Travel? By car? Boat?
    In questions like yours, specifics help. Maker/brand, model, web URL. Generic questions without specificity will gain you little in the way of definitive answers.
  3. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,668
    8,120
    Iowa
    When it comes to tripods, there's an age-old maxim: Quality, Light Weight, Low Cost...... Pick Two.
    • Like Like x 2
  4. astroNikon
    astroNikon 'ya all Bananas I tell 'ya Supporting Member
    Aug 15, 2013
    13,291
    3,231
    SE Michigan
    To make Carbon Fiber cheaper they simply use less layers, and may not alternate the pattern for strength. This makes it much cheaper to make, and much more prone to easy breakage.
    So, it all depends upon the exact make, model, etc of tripods you are comparing.
    • Agree Agree x 1
  5. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    Unless you want to spend several hundred dollars on your tripod, aluminum is the way to go.
    • Agree Agree x 1
  6. snowbear
    snowbear TPF Noob! Supporting Member
    Dec 9, 2006
    13,049
    4,626
    SoMD
    And buying a low quality, cheap tripod will ultimately mean buying a second tripod (not so cheap) to replace the first one when it breaks / fails / disappoints.
    • Agree Agree x 2
  7. smoke665
    smoke665 TPF Supporters Supporting Member
    Mar 29, 2016
    5,172
    2,177
    Alabama
    And part of the decision should be how much you plan on using it. I just replaced one of my "cheap" aluminum tripods after only 20 years of occasional use!!! One of the leg clamps broke, but I liked the thing so much that a hose clamp repair and it still works for a reflector.
    • Agree Agree x 1
  8. Designer
    Designer Been spending a lot of time on here!
    Apr 13, 2012
    16,236
    4,073
    Iowa
    Aluminum will not last if you habitually set it up in salt water. Eventually aluminum will corrode under those conditions. That does not completely absolve carbon fiber from the same type of corrosion if there are any aluminum fittings on the tripod. The better makes may warrant their product for regular salt water use. Be prepared for sticker shock.
    • Agree Agree x 1
  9. Overread
    May 1, 2008
    24,009
    4,153
    UK - England
    For salt water use the general advice is to get a good quality tripod that lets you dismantle it - you then take it apart and clean all the parts in fresh water (ideally distilled as that has no mineral content).
    As the others have said, carbon fibre has the bonus of being noticeably lighter; but only if its a quality make will it have the durability. There are also comments on vibrations (esp with regard to AF) and I can't recall, but either of the two material types carries vibrations a little better than the other; but this is very marginal territory in terms of image quality (unless you're shooting very slow speeds and can't use the mirror-lock-up between shots).
    Another aspect if what kind of gear you're going to use; some camera and lens combos are very heavy and thus demanding; whilst others are much lighter and you can get away with a cheaper tripod; sure its not as durable but it might be all you need.
    However weight is the most common reason people go for carbon fibre. More expensive but when a quality item is bought it performs very well and lets you have reduced weight to carry around.
    • Agree Agree x 1
  10. unpopular
    unpopular Been spending a lot of time on here!
    May 17, 2011
    9,424
    1,973
    Montana
    Diamond encrusted gold!
    Do not buy a new tripod. They depreciate rapidly and this is one thing you're better off buying used.
    But no matter what, you ought to spend more on a tripod than you think you should. I personally use a heavy aluminum manfrotto, the weight does not bother me much, and I honestly kind of like having the bulk to help weigh things down. But I certainly can appreciate why people would prefer something lighter weight or corrosion resistance.
    One thing I do regret is not having a decent head.
    A good tripod should withstand being thrown off a cliff. Literally. When it's either you and your camera or your tripod, you're going to want the option of dropping your tripod first without thinking twice.
    • Like Like x 1
    • Winner Winner x 1
  11. astroNikon
    Aug 15, 2013
    13,291
    3,231
    SE Michigan
    FYI, my tripods are SLIK tripods of which the smallers ones have their A.M.T. - Aluminum, Magnesium & Titanium alloy that is supposedly lighter and stronger than a regular aluminum tripod system. I really have no idea if it is or isn't but it holds my heavy lenses just fine (700 & 500 series legs). I also don't know of their corrosive to salt water if used near an ocean. But it's another alternative to look into if that is a requirement.
    • Informative Informative x 1
  12. Gary A.
    Gary A. Been spending a lot of time on here!
    Top Poster Of Month
    Sep 17, 2014
    19,068
    6,144
    Southern California
    480Sparky and unpopular both delivered some very good advice. I have both, a very nice metal and a very nice carbon fiber, I use the carbon fiber more because of ease of transport.
    • Agree Agree x 1
