An Attempt at an HDR
Discussion in 'HDR Discussions' started by dustinpedley, Aug 31, 2009.
  1. dustinpedley
    dustinpedley TPF Noob!
    Nov 23, 2008
    93
    Missoula MT
    I posted this in the beginner section Sunday but i thought i might get a little better response here.
    I wasn't going for a way overdone HDR something a little more natural looking
    How can i improve these?
    Thanks in advance
    [​IMG]
    [​IMG]
  2. *mithrandir
    *mithrandir TPF Noob!
    Sep 1, 2009
    Maryland
    Both appear a bit soft. You might want to used a fixed aperture of f/16 for all of your shots? Did you use a tripod? If it was windy, the trees are going to look soft (blurred).
  3. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    Looks a bit washed out.
  4. Opher
    Opher TPF Noob!
    Aug 7, 2009
    448
    5
    Kitchener ON
    Try to boost the contrast a bit.
    [​IMG]
  5. AdamBomb
    AdamBomb TPF Noob!
    Nov 14, 2008
    200
    Ann Arbor, MI
    Now the rock and clouds are blown.
    My attempt:
    [​IMG]
  6. Opher
    Opher TPF Noob!
    Aug 7, 2009
    448
    5
    Kitchener ON
    Much better :D
  7. AdamBomb
    AdamBomb TPF Noob!
    Nov 14, 2008
    200
    Ann Arbor, MI
    Basically I played around with the levels, sharpened, and did some burn/dodging
  8. |)\/8
    |)\/8 TPF Noob!
    Jun 23, 2007
    335
    Duluth, Ga.
    Your photos look kind of flat, they need a contrast boost. Here is a quick 5 min edit (maybe a little overdone, but you will get the point). I ran a high pass filter on it and adjusted the contrast and played with curves a little.
    [​IMG]
  9. pez
    pez Been spending a lot of time on here!
    May 29, 2008
    1,174
    500
    N Georgia
    Here's one with channel add/subtract layers and curves. :D
    [​IMG]
    [​IMG]
  10. McNugget801
    McNugget801 TPF Noob!
    Jul 13, 2009
    388
    43
    I could do a much better job if I had the RAW files used to create this image. Here is my end result after doing a bit of tonemapping in Photomatix and touch up work in LR2.
    [​IMG]
