An attempt at photshop b&w
Discussion in 'Critique Forum Archives' started by Dracklord, Aug 29, 2006.
  1. Dracklord
    Dracklord TPF Noob!
    Aug 21, 2006
    21
    Jackson, Mi
    I photoshopped this into b&w... I've included the original for comparison
    [​IMG]
    And the original color.
    [​IMG]
    Don't be shy.. both are OTE, just tell me what and why
  2. Weaving Wax
    Weaving Wax TPF Noob!
    Aug 23, 2006
    678
    U.S.
    I think it has a character, but it's a little "dull" in the contrast dept. I'd mess with the brightness and contrast a little bit and shadows and highlights. I still think its a great picture..
  3. Salty_Fetus
    Salty_Fetus TPF Noob!
    Aug 27, 2006
    16
    Yeah, its lacks in contrast. One good way to fix that is to go into curves and make it an s-shape curve to your liking.
  4. Dracklord
    Dracklord TPF Noob!
    Aug 21, 2006
    21
    Jackson, Mi
    Do what in photoshop with curves? Sorry, I'm new to this stuff. Taking the shots with a minolta x-700, these were taken with the 50mm 1:2 standard lens. Only reason I have ps 7 is cause a buddy gave it to me.
  5. Weaving Wax
    Aug 23, 2006
    678
    U.S.
    Photoshop has a feature called "Curves". "Image"---> "Adjustments"---> "Curves". You will see a single virtical line. When you click on it, little boxes show up. You can create enough of those boxes to create an "S" shape. I haven't done too much with the curves feature, but I'll try this out next time I need to adjust contrast for some B&W Photos.
  6. JamesD
    JamesD Between darkrooms
    Mar 20, 2005
    1,025
    12
    Living in Snapshot reality.
    I like this image in both forms. It has a retro feel to it. If anything, I'd suggest lightening the shadowed areas under the canopy. A bit of on-camera fill flash at exposure time might've worked quite well for it (with the camera upside down so the flash is lower than the lens to prevent the front of the canopy from casting a shadow on the inside of the back of the canopy).
    I like the feel, though, and it could be argued that the missing detail in the shadows adds to the retro look.
  7. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    Since you said it was okay to edit I did
    [​IMG]
    Since im about retro I tried to make it retro. I have a small program that does aged sepia. It raises the contrast as it applies the sepia. I changed the gamma a little. Did a sepia then Tarnished the sepia (desaturated). then I used the airbrush with a little color to tint in spots rathe than tint completely.
  8. KevinR
    KevinR TPF Noob!
    Feb 1, 2005
    1,204
    4
    Dearborn, MI
    The first needs contrast like the others said. But I would even try a sepia look to it. Although the one mysteryscribe did is cool, I think it still needs a little pop and some more of the brown tones.
  9. Dracklord
    Dracklord TPF Noob!
    Aug 21, 2006
    21
    Jackson, Mi
    Interesting. I'm not sure I like b&w for most things, but it seems to fit this image and a few others like it... I will try the sepia, and see if I can get a result I like. I wish I could find a better tutorial on how to use the curves feature, every time I touch it I just make the image look worse.
  10. zombiekilla
    zombiekilla TPF Noob!
    Jul 31, 2006
    363
    Wisconsin
    try good-tutorials.com
